Search found 511 matches
- Mon Aug 08, 2016 10:26 am
- Topic: 216 dohc timing belt swap
Re: 216 dohc timing belt swap
Belt change is easy once you have removed the engine mount and lower crank pulley bolt , which is on extremely tight, it took me about 1.5 hours to change the single cam belt and that was with a new pump and a few cups of tea. On the twin cam you don't even need to remove the cam cover as the timing...
- Tue Jun 28, 2016 8:13 am
- Topic: Auto box stuck in 1st/2nd
Re: Auto box stuck in 1st/2nd
Driving in D3 should have no detrimental affect on the car whatsoever, I used to often leave mine in D3 if i was in traffic and while going up steep hills of which there are many where I live I would keep it in 2. I sounds like sticking clutch plates or worn plates, but if it was worn clutch plates ...
- Mon Jun 27, 2016 7:30 am
Try leaving it in D3 and drive it like that for a while, including high speed trips like on dual carriage ways, also put it in 2 every so often but not above 40mph, My old 416 was apparently not pulling away in 1st but after doing the above and giving it a good thrashing it now works better than eve...
- Wed May 04, 2016 9:50 am
- Topic: 416 GTi broken down - help/advice sought!
Re: 416 GTi broken down - help/advice sought!
Its almost certain that it will be the igniter inside the distributor, they are about £20, it takes about 30 min to fit, failing that it might be the brown fuel pump relay behind the center console, can you here a click when you turn the ignition on?, then a second click as the check light goes off,...
- Sat Mar 26, 2016 3:15 pm
- Forum: Events and Meetings
- Topic: Bristol Classic
Re: Bristol Classic
I'll try and get to this, I would have made the trip up to a meeting but I'm in Crewe all weekend, I could have my 416 Gsi available for it.
- Thu Mar 24, 2016 10:33 pm
Re: Bristol Classic
When is the show this year?
- Wed Jan 27, 2016 10:43 pm
- Topic: Brake master cylinder
Re: Brake master cylinder
The Handbrake work perfectly, now I have noticed over the past few weeks that sometimes when the pedal is pressed it would drop a further inch or so, while there's pressure on it and that was before the pads and discs were changed. The pedal does firm up when the engine is off but it does sink slowl...
- Tue Jan 26, 2016 11:16 pm
Thanks for the reply's, I've bled the brakes to an inch of their lives and still no difference, I've got a replacement master cylinder which I'm going to try when it eventually stops raining.
- Sun Jan 24, 2016 11:15 pm
After changing my discs and pads I now have a brake peddle that goes half way down before it slows the car down, I suspect a failing master cylinder, does anyone know where I can get a re build kit or a very reasonable priced new item from, oh its 1993 416 non ABS model.
Thanks.
Thanks.
- Sun Nov 01, 2015 8:27 pm
- Topic: HONDA MAIN RELAY - DEFINITIVE / SELF BUILD
Re: HONDA MAIN RELAY - DEFINITIVE / SELF BUILD
Fantastic article, it's more right ups like this we need
