Search found 24 matches
- Wed Sep 09, 2020 11:08 am
- Topic: Engine wiring
Re: Engine wiring
Ecu is mkc103400, engine is in a kit car, so no fobs or immobiliser.
- Wed Sep 09, 2020 9:31 am
Re: Engine wiring
I’ve tried several coils. There’s no beg pulse to coil from ecu. I’m thinking ecu fault as well..
- Wed Sep 09, 2020 5:27 am
Re: Engine wiring
I’ve got a reply from Paul, “I don't believe this is an immobiliser issue as the engine ECU only stops
the injector drive when immobilised, the ignition coil drive is not affected.”
- Tue Sep 08, 2020 5:27 am
Re: Engine wiring
I have tried to contact him. No reply.
- Mon Sep 07, 2020 5:46 am
- Sun Sep 06, 2020 6:30 pm
Re: Engine wiring
Had a look, injectors are not firing. Plugs are dry.
- Sat Sep 05, 2020 10:18 am
- Sat Sep 05, 2020 6:10 am
Re: Engine wiring
Just read about “ecu vacuum connector”, does that need to be connected??
- Sat Sep 05, 2020 5:43 am
Re: Engine wiring
Yes, no spark. Wiring checked, coil checked. Fuel pump primes, have fuel pressure, coil has feed, ecu not switching the coil.
- Thu Sep 03, 2020 11:20 am
Re: Engine wiring
Just checked, ecu is Rover M.E.M.S, mkc103400, crank sensor has ac voltage to ecu plug. No spark..
