Search found 19 matches
by Lerich
Mon Aug 04, 2025 9:07 pm
Topic: Rover 200 Story on YouTube
Re: Rover 200 Story on YouTube
The BigCar channel is great. I recommend watching his videos - they're very informative and well constructed.
by Lerich
Sat Oct 26, 2024 8:39 am
Topic: New R3 214i SE Owner - Recomissioning?
Re: New R3 214i SE Owner - Recomissioning?
My first Rover was a 214i SE. Loved that car and it served me well despite the engine sounding like a bag of spanners. The 214i SE is very unusual for an R3 200 in that it had standard fit air conditioning. As suggested, replace all fluids and filters. Do multiple flushes of the cooling system. Afte...
by Lerich
Thu Mar 17, 2022 9:16 pm
Topic: MOT advice for a new member/owner
Re: MOT advice for a new member/owner
The fan speed fault is very very common, caused by the fan resistor failing. It's located in the fan motor housing, easily accessed by removing the glovebox. You can either replace or replace. Later R3s like the Streetwise had cheapy Pektron clocks which often fail. They are easily replaced by a goo...
by Lerich
Mon Mar 07, 2022 9:42 pm
Topic: Re-glueing R3 door fabric - Quick guide
Re: Re-glueing R3 door fabric - Quick guide
Good effort!
by Lerich
Sun Jan 30, 2022 8:04 pm
Topic: Rover 25 Rear Wiper Motor - Washer Blocked
Re: Rover 25 Rear Wiper Motor - Washer Blocked
I had this exact same issue with the rear washer on my Vi. I thought initially I had a blockage or split further forward then found that the washer pipe discharged fine if disconnected from the entry into the washer motor. I tried the same sort of fixes that you have, sadly without success. Eventual...
by Lerich
Sat Jan 22, 2022 9:19 pm
Topic: Are they out there?
Re: Are they out there?
Try popping the reg's in the gov vehicle enquiry site and see what it brings up.
https://vehicleenquiry.service.gov.uk/?locale=en
by Lerich
Tue Dec 28, 2021 9:46 pm
Forum: Project Cars
Topic: 1995 214 Sei BRG
Re: 1995 214 Sei BRG
Looks a sound project. An SEi is worth it for those seats alone.
by Lerich
Tue Nov 16, 2021 8:44 pm
Topic: R3 Bumper chrome insterts
Re: R3 Bumper chrome insterts
Is it a good match to the original? Yes it's pretty decent. I've not fitted it yet (beyond a trial fitting) but it fits the channel perfectly. The only difference is it doesn't sit as proud as the OEM strip as it's not as deep. How long it'll last as it's cheap chrome-plated plastic remains to be s...
by Lerich
Tue Nov 16, 2021 7:52 pm
The bumper needs to be off the car to remove the chrome strips to avoid damaging them as they clip in. The strips on my Vi have partially delaminated. I removed the rear strip (which snapped in the process) but the bit that remained intact is good enough to reuse on the front corner. I've sourced th...
by Lerich
Mon Nov 15, 2021 9:22 pm
Topic: Looking for a Streetwise
Re: Looking for a Streetwise
The Streetwise was available with the 103ps 1.4, 1.6 and 1.8 Stepspeed as well as the 84ps 1.4, if performance is a concern ;) Build quality isn't amazing on the Streetwise as it was born at the height of MG Rover's cost cutting frenzy. But if you ignore the cheap materials and lack of refinement th...
