Search found 7 matches
- Thu Feb 24, 2022 8:54 pm
- Topic: Stuttering wipers on intermittent setti g
Re: Stuttering wipers on intermittent setti g
Hi Bob the Brush - sorry to grab hold of your post from two years ago, but I have the same fault with the windscreen wipers and the car has failed it's MOT due to it. Did you manage to fix it or was a replacement required? I am asking as I have looked for a replacement and finding one is looking qui...
- Sun Feb 07, 2021 7:29 pm
- Topic: Cabriolet is difficult to start
Re: Cabriolet is difficult to start
Thank you to all for your suggestions. I tried the earthing points (all that I could see) & didn't get round to the crankshaft sensor or compression test, however after replacing the mid exhaust it is starting first time every time since! Never realised the exhaust could cause a problem to star...
- Sun Feb 07, 2021 3:39 pm
Thank you to all for your suggestions. I tried the earthing points (all that I could see) & didn't get round to the crankshaft sensor or compression test, however after replacing the mid exhaust it is starting first time every time since! Never realised the exhaust could cause a problem to start...
- Thu Jan 14, 2021 9:10 pm
Itcaptianslow, thanks, I will take a look on Sat/Sun. As for occuring since the H/G - not really, but it has worsened. I assumed the starter motor was causing most of the starting fault. Had it 18 months and starting was occasionally an issue but infrequently, and always started after a few tries. H...
- Thu Jan 14, 2021 9:02 pm
Have you had the battery checked? (Halfords will test for free, but other places are cheaper). It is possible the battery is no longer able to hold a decent charge.
- Wed Jan 13, 2021 4:59 pm
Thank you all for your comments - given me a busy weekend! 👍 RoverRevival, copper grease purchased & I tried to do this today but was rained off - try again at the weekend (assuming it's dry)... Kriss707, the rotor arm has been replaced (same time as the leads) but I omitted it from my list in e...
- Tue Jan 12, 2021 4:26 pm
Hello, First time poster here (& new to the forum) so if I have done something wrong please tell me not shout and I will sort 🙂 I have looked through previous posts before typing and couldn't find and answer. My 1998 Rover Cabriolet 1.6 is giving me issues when I try to start it. Occasionally it...
