Bit late to the party here but I haven’t had any messages from you...
Search found 18 matches
- Sat Nov 21, 2020 9:53 am
- Topic: Engine wiring
- Sun Sep 09, 2018 4:59 pm
- Topic: new remote fob 1994 216 cabriolet
Re: new remote fob 1994 216 cabriolet
Cheers guys!
- Thu Jul 20, 2017 9:41 am
- Topic: Central locking not working -> alarm?
Re: Central locking not working -> alarm?
I could get the EKA code but it wouldn't solve your other issues. The door lock popping back up again a couple of seconds after it is locked is a fault with the locking mechanism/actuator or door switch. I've also seen this happen when the rod that's connected to the lock pin you can see above the d...
- Tue Nov 22, 2016 8:09 pm
- Topic: Another Alarm/immobiliser problem Rover 216
Re: Another Alarm/immobiliser problem Rover 216
If you were nearer I would be keen to plug in your 5as and see what's going on with it. I have a bench rig here that I built which is effectively a car in a box, just enough for the ECU and 5as units to communicate effectively so they can be programmed off the car, these are pretty basic in terms of...
- Sun Oct 02, 2016 8:51 am
- Topic: Fob resync not working / Immobiliser won't disable - Rover 220 GSi Coupe
Re: Fob resync not working / Immobiliser won't disable - Rover 220 GSi Coupe
Already spoken via PM
- Thu Sep 22, 2016 9:24 pm
- Forum: The Lounge
- Topic: New venture!
Re: New venture!
Still there on the side as and when required. It is getting difficult to get hold of fobs these days though. I used to have a good stock of them but I'm left with nothing but 3txa now, only suitable for the very old cars. I still program when needed but depends if I can get the fobs when I need them.
- Thu Sep 22, 2016 8:08 pm
- Forum: The Lounge
Re: New venture!
Cheers guys, any particular font?
- Thu Sep 22, 2016 2:24 pm
- Forum: The Lounge
New venture!
Hi all, As most of you will know, I program keyfobs and do some immobiliser work. I am still doing this but it has taken a sideline now as I am working more on another venture. I have recently (over a year ago now) started a business producing a variety of things such as mugs, tshirts, hoodies, cut ...
- Fri Sep 16, 2016 7:39 pm
Let me know if I'm needed
- Tue Jan 20, 2015 11:32 pm
- Topic: Rover 214 Key fob question
Re: Rover 214 Key fob question
Will be back with you Thursday all being well with Royal Mail Steve!
Many thanks again.
And thanks for the comments 220gsi turbo and John!
Many thanks again.
