Search found 236 matches
by MatthewL
Thu Oct 22, 2026 5:46 pm
Topic: T-Series - priming oil pump
Re: T-Series - priming oil pump
Resolved! Cleaned up the old sender and gave it a longer run on the starter motor. Pressure achieved
by MatthewL
Wed Oct 21, 2026 10:27 pm
Has anyone had any experience of issues getting oil pressure after work on a T-Series engine? I’ve replaced the sump and head gasket. I removed the plugs and LT leads from the coil but after turning over the engine using the starter I’m not seeing the oil pressure light go off. I don’t want try for ...
by MatthewL
Mon Oct 12, 2026 7:45 pm
Topic: Bulbs and holder - R8 heater controls
Re: Bulbs and holder - R8 heater controls
Correction. T4.7 bulbs!
by MatthewL
Sun Oct 11, 2026 9:29 pm
After much research I think it’s a T4.2 bulb and holder - ordered so hopefully solved!
by MatthewL
Sun Oct 11, 2026 5:25 pm
There are 2 flat backed bulb holders in the heater control panel. They look like standard 1.2v dash bulbs (maybe long as long?) but these holders are so shallow I didn’t know if the bulb could be swapped or if I needed a bulb and holder from somewhere- they look pretty bespoke. Anyone out there chan...
by MatthewL
Mon Sep 14, 2026 9:33 pm
Topic: SRS Warning light on.
Re: SRS Warning light on.
Different car but my old BMW had this issue - the seat sensor pad had failed on the passenger side. I fitted a little plug on the loom which makes it think the seat is occupied. In a crash both airbags would go off rather than just the drivers but I figured such a crash would write the car off anywa...
by MatthewL
Tue Sep 08, 2026 10:39 pm
Topic: 420GSI Tourer various fixes
Re: 420GSI Tourer various fixes
I’ve been really slack in providing any updates on my car. I realised I’ve had Roy for 5 years now. I was having some serious oil leaks which I’d been putting off addressing but the time finally came. The car was dripping on the driveway - it transpired the front of the sump had rusted through. http...
by MatthewL
Sat Jul 25, 2026 9:57 am
Topic: Rubber grommets for T-series belt covers
Hi everyone My gushing oil leaks have necessitated a new head gasket. Whilst the head is at the engineers for valve seals and (if needed) skim/mating face clean up, I am trying to clean up all the peripherals. The covers for the timing belt have a number of soft grommets - does anyone know where I c...
by MatthewL
Mon Jun 15, 2026 4:03 pm
Topic: Philips R960 remote steering wheel controls for R8
Re: Philips R960 remote steering wheel controls for R8
Yes I’m using the resistance capability (messing up your 200ohm) on the voltmeter to see if I can see a reading when the buttons are engaged and therefore, I assume, making a circuit with a resistor in it. Can’t get a reading though so I’m doing something wrong.
by MatthewL
Sun Jun 14, 2026 6:35 pm
Forum: The Lounge
Topic: Austin Rover on BBC 5Live
Re: Austin Rover on BBC 5Live
Brilliant John - love it!
