Search found 5 matches
by frendok
Fri Dec 19, 2025 10:59 am
Topic: T-Series vibration
Re: T-Series vibration
Hi, sounds like it could potentially be something as simple as wheel balancing, I would definitely start here, if that doesn’t fix the vibration a drive shaft is another potential cause.
by frendok
Wed Dec 17, 2025 7:49 am
Topic: R8 GTI SILL Flare Fixings
Re: R8 GTI SILL Flare Fixings
Hi Plodder, Thanks for the reply, I'm thinking of bonding the plastic locating clip to the sill panel, then I can at least still remove the sill flares for cleaning periodically, the main issue for me is the lower edge of the sill flare and how this attaches as I did not have a reference point to st...
by frendok
Tue Dec 16, 2025 4:52 pm
Hi, I'm currently in the process of putting my car back together but am unsure of how the lower edge of the sill flare attaches to t5he sill, I can see the clips (DYC10074LOQ) on Rimmer Bros but I'm not sure how they locate as the sill flares were off my car prior to me dismantling. Would anybody ha...
by frendok
Tue Jun 10, 2025 9:57 pm
Topic: 200 R8 Rear Light Cluster Electrical Connectors
Re: 200 R8 Rear Light Cluster Electrical Connectors
Many thanks, only the most important detail to forget. Now added :oops
by frendok
Tue Jun 10, 2025 2:51 pm
Hi All, Would anybody know if it is possible to buy the pins/harness repair kit for the rear light cluster connectors on a R8 200? the pins in mine have been broken at some point. I'm not keen on cutting the complete connector off and soldering in from donor harness as I want to keep the harness ori...
