Windscreen wiper stuck
Brum
Post by Brum »
I have a 1993 River 416 1993 and when I turn the wipers off it’s staying on intermittent?
Re: Starting problems again!!
no spark leads you to look at coil, plugs, leads, dizzy, rotor, crank position sensor and proper gaps on plugs (if new).
Post by Paul_1978_yorks »
Pound to a penny it’s the rotor arm!
Cheap fix too so got to be worth a try.
rover416
Post by rover416 »
One of my K series engined tourers has a love of rotor arms, the new replcements don't seem to last long I,ve taken to carrying a spare in the car along with a socket to change it. Ironic that in my original tourer which I still have, it's done over 240K on the same one.
Brum
Post by Brum »
Hi thanks for your replies the Rotor arm was replaced not that long ago but the RAC guy did say there was a tiny bit of scoring on it my hubbys just put jump leads on it and it started within 2 seconds even though the battery was showing it had 12.3 charge in it before he put them on it has done this before probably run for a few days and then won’t start again could it be something to do with the relay? The guy at the garage said if it did it again try knocking it?
have you resoldered the mfu? (assuming honda)?
Brum
Post by Brum »
It is the Honda 1.6 engine what is the Mfu? Thanks Beverley
The brown fuel relay under the dash at drivers side a pillar.
1234dist wrote: Mon Mar 04, 2019 6:57 pm The brown fuel relay under the dash at drivers side a pillar.
This is the fuel relay and a very common starting, which often starts with re-starting problems. It sits 'round the back of the centre console by the front passenger's ankles
The MFU is the Multi Function Unit that sits behind the interior fusebox, situated above the driver's shins, which I'm not sure is repairable...
My money's on the relay if it's not the dizzy
i'll happily do the solder work if you can get to me
