Hi,
A couple of issues that have come to light due to the recent weather, I have water in the boot on the driver's side and gave worked out that it is from the vent and the top of the light, that water is getting in, now I know that I have to take the bumper off to do the vents, is it just a matter of using sealant to replace the perished gaskets or do I get/make new ones, if so what is best to use, as for the lights is that just a case of using sealant to seal them.
Finally which sealant do you recommend for this job
Thanks in advance
Ron
Water in boot
Re: Water in boot
Which car is this for?
Re: Water in boot
A 1992 rover 216 gti
Re: Water in boot
I used tiger seal to seal in those vents with new bolts to replace rivets
Then sealed the gaskets on the lights to the light
No leaks
No leaks
Re: Water in boot
Thanks Vinny1979, can you remember the size of the bolts to replace the robots, I'd like to get them before I start, next week hopefully, as the weather improves
Ron
Ron
