Rover 45 front disc upgrade
Kriss707
Post by Kriss707 »
After some advice please...
My Son wants to upgrade his Rover 45 front discs from solid to vented, they're the larger 262mm.
He has sticky callipers to replace, if its just wider vented callipers & the Discs, he will get the vented items & they (hopefully) bolt straight on.
Re: Rover 45 front disc upgrade
Assuming the 45 is the same as an R8 the answer is no! the steering knuckle needs changing as well as the carrier.
Cromp85
Post by Cromp85 »
With it being a 45, I think the hub knuckles are the same as a ZS. Calipers and matching carriers should be all you need (With disks & pads)
2002 MG ZR 105 in Solar red
1995 214i in Nightfire red
isn't this the conversion that requires the 1mm spacers washers on the carrier too so it doesn't touch the disc?
Kriss707
Post by Kriss707 »
Job jobbed today, used my spare set of refurbished calipers & carriers from a 216 Cabriolet (the Boy owes me now :laughing2 :laughing2)
The 45 calipers were 10mm(ish) narrower & the carriers were the same but for a small lip, which could easily be removed with a grinder to accommodate the wider vented discs if needed.
