SRS light
Alagre
SRS light
Post by Alagre »
SRS airbag light is staying on after start up on my 96 cabriolet, looked on you tube and all later rovers seem to be an easy fix by cleaning the yellow connector under the seat but alas my car doesn’t have any so any ideas where to start please??
Cromp85
Re: SRS light
Post by Cromp85 »
Try checking the SRS Fuse. The warning lamp will also stay on if the fuse is blown/removed.
2002 MG ZR 105 in Solar red
1995 214i in Nightfire red
Re: SRS light
cut the yellow connector off and replace it with bullet connectors.
Alagre
Re: SRS light
Post by Alagre »
RoverRevival wrote: Wed Aug 03, 2022 5:00 am cut the yellow connector off and replace it with bullet connectors.
My car doesn’t have the yellow connectors just a pre tensioner but thanks for your reply
Re: SRS light
the tensioner has o plug into something.
Re: SRS light
RoverRevival wrote: Wed Aug 03, 2022 4:11 pm the tensioner has o plug into something.
Pretensioners on the R8 are mechanically-activated (some kind of ratchet action, I believe) and there is no electrical connection to it.
I don't know if this changed with the very late cars (with the R3 dash).
rjessett
Re: SRS light
Post by rjessett »
as above - mechanical pretensioners on this, so no connectors under seats.
Im 95% certain it will be the rotary coupler on the steering wheel. cheap and easy to change
Although - I have just fixed a car that it was the Airbag ECU had gone faulty. Never seen or heard of that before!
Alagre
Re: SRS light
Post by Alagre »
The tensioner doesn’t plug into anything so I’m assuming it’s mechanical like the ones on the old corsa
Alagre
Re: SRS light
Post by Alagre »
220 GSi turbo wrote: Wed Aug 03, 2022 9:34 pm
No it’s still the same on mine and it has the later dash thanks 👍
Alagre
Re: SRS light
Post by Alagre »
rjessett wrote: Wed Aug 03, 2022 11:36 pm as above - mechanical pretensioners on this, so no connectors under seats.
Where would that be available from please? And thanks for your reply
