420GSI Turbo MKC101960 ECU
MissGLT
Post by MissGLT »
i have a 420 gsi which currently isnt starting, fuel pump isnt priming, but runs if relay is bypassed fuse is ok
i dont hear the stepper motor when the ignition is turned on
"Born in the 90's, living for 90's financial mistakes" :slapme
Amaranth 216 cab, Nightfire 420 GSi, BRG 420 GSi Turbo, Tahiti FDH Coupe, Mk1 820 SPi, R33 Skyline resto
rjessett
Re: 420GSI Turbo MKC101960 ECU
Post by rjessett »
MKC101960 is partnered with the 5AS ECU.
Is the immobliser/central locking working off the fobs, correctly?
Is the engine running when the fuel pump is bypassed?
MissGLT
Post by MissGLT »
Hi,
no the engine doesnt run when the relay is by-passed
the doors do open and close on the fob, but the armed light on the dash does flashs not in the normal sequence, when disarmed the light does eventually stop flashing
Cromp85
Post by Cromp85 »
Have you checked the slam panel earths? I think there is a black thin gauge wire going to the ECU, a break or corrosion on this and the engine won't run.
2002 MG ZR 105 in Solar red
1995 214i in Nightfire red
