216 XW Honda Engine D16A8 Convertible
eternalstudent
Post by eternalstudent »
Hi Community,
Thanks for having me :clapping , I have a 216i XW 122HP Honda Engine D16A8 Convertible from 1994. I am here to get and share knowledge.
I am from germany and excitited to get with knowledge my good old car back to its glory time. :D
LG
Re: 216 XW Honda Engine D16A8 Convertible
Post by StubbornPatriot »
Welcome to our friendly club LG. You've come to the right place then. Lots of help and enthusiasm here to support you in your ambitions. Would be good to see a picture of your car and we look forward to chatting with you on here. Good luck with the Cabby. Cheers, Duncan.
eternalstudent
Thank you very much Duncan. I am already busy posting. :laughing2
eternalstudent wrote: Thu Aug 29, 2024 8:25 am Thank you very much Duncan. I am already busy posting. :laughing2
Your car seems rather late for a D16A8 engine, that is the earlier non-cat DOHC engine that makes a lot of power for sub 1600cc The book figure was 130 BHP 122 is with a cat fitted. It's important to establish the build order because there are a number of differences.
eternalstudent
Mr Teddy Bear wrote: Sat Aug 31, 2024 8:36 am
Yes you are right. But it is a cat fitted with 122 HP. And yes, I replaced the Engine with the same DOHC Engine from an accident donor car. Because my engine burned off.
Luckily we could find a cheap accident one with a good motor.
I would get the ECU as well if possible, it may have a different ign' advance curve and fuel map. The two heads differ in regards to the cams. The Honda engine workshop manual refers to this.
eternalstudent
Mr Teddy Bear wrote: Sat Aug 31, 2024 10:48 pm I would get the ECU as well if possible, it may have a different ign' advance curve and fuel map. The two heads differ in regards to the cams. The Honda engine workshop manual refers to this.
Ohhhh. This advice is very nice. I had this feeling when I saved the ECU, that it could be only work perfectly when it has its original ECU.
My question now is, if i install the original ECU does it have any effect to the key fob alarm system? Which is by the way very poor. I have to stand 30cm - 1m from the car to open and close the car by the remote. From 2m - 10m it is impossible to open/close the car. Batteries are new and I soldered new smd switches and a new quartz. No improvement. Unfortunately I have only one set of doorkey and fob.
Proximity isn't really a disadvantage if you think about it.
Do a search there are experts around who can re-programme fobs and the ECU I expect.
