Engine identify
Benj
Engine identify
Post by Benj »
Hi all, I own a rover 420 sli 2.0 litre 16v
Now i looked up the k-series which is what i thought it was because the gearbox was on the left but it said they were only made up to 1.8 litre capacity, so what is mine? is it a t-series?
Post by E_T_V »
Yes it is almost certainly a T series. A rover engine, and very relaible. The only gripe with many of them is a weep of oil from the front passenger side of the headgasket which can be considered as normal.
syzsounds
Post by syzsounds »
Got pics ?
Gearbox on the left if you look from the front ??
Benj
Post by Benj »
gearbox on the right, so its definately a rover engine
pic:
syzsounds
Post by syzsounds »
Yep ..Rover T series.
Cracking little engines, I miss my NASP tourer ... :sad
Benj
Post by Benj »
i have noticed my oil does need refilling every 3-4 months or so, do you think this could be the oil weep from the head gasket problem?
syzsounds
Post by syzsounds »
Benj wrote:i have noticed my oil does need refilling every 3-4 months or so, do you think this could be the oil weep from the head gasket problem?
If its leaking from the front right hand corner then yes thats the standard problem.
