passenger window rattel on cabbie
xadowbg
Post by xadowbg »
when i have the passenger window fully closed it makes a rattling noise. when i get it down its all good and quiet. i got the door striped to look inside to check if there is something loose but all seems fine...
any one has my same problem any advice?
cheers tnx
discodude
Re: passenger window rattel on cabbie
Post by discodude »
i have this prob with mine!think its because the window sits against a rubber seal rather than fitting into a metal groove that you get with tin top cars.just turn radio up!i sometimes drop window a couple of mm.does the trick.
nick-webb
Post by nick-webb »
Check the clips on the base of the window, securing it to the regulator.
They're known to fail - and rattle is an early sign.
carpy
Post by carpy »
As it happens my drivers door window does the same but only when it's raining and not every time, go figure :S
xadowbg
Post by xadowbg »
the clips are fin but is there any cure? oor i should just get used to it?
discodude
Post by discodude »
get used to it.you live in malta so plenty topless fun!
xadowbg
Post by xadowbg »
*laughs* yea :laughing2
