Changing headlamp?
214GSI
Changing headlamp?
Post by 214GSI »
More advice than help.
Changed a headlamp today.
My haynes manual 89'-'92, did not mention the lower bolt that has to be slackened to enable the headlamp to slide clear of the support.
If I had not been cautious- I could easily have attemped to pull the lamp out and broken the plastic mounting.
The plastic trim piece below the lamp is a bit flimsy, and looks easy to break.
1990 214GSI- spares died at 121k
1995 214SI- daily runner 95K
2004 MG ZS 120 - sunday best car 28k
Post by E_T_V »
Yes the lower bolt is a pain to get at unless you have fog lamps you can remove to get access to them.
Also the plastic "hockey stick" under the lamp is indeed fairly fragile. I don't think I ever remember seeing one that had all its clips intact!
Also as a side note, if you want to remove the bumper, don't take any notice of the manual that says you have to remove the headlamps. You don't as I found out lastnight when I was stripping the car apart.
tomcat216
Post by tomcat216 »
If I remember correctly, my '93 Coupe didn't have that bolt underneath the headlight. I wonder if thats because it wasn't an adjustable one.
I may be wrong though.
Mark
'98 Tahiti 216SE Coupe
'99 Charcoal 420SLDi
'96 Silver BMW 525td
'93 Ford Mondeo 1.8LX
'93 Dulux Yellow 216 Coupe - RIP
