Universal Electric Windows / Remote Central Locking
214cab
Post by 214cab »
Are these universal kits any good? Consider fitting them to my cabby, i did start collecting the electric window parts to retro fit but none of the main loom wiring is in place so thinking it might be easier to use a universal kit.
As my early cabriolet is key operated locking too, thinking of fitting a remote central locking kit whilst i'm in there aswell.
RGNEAVE
Re: Universal Electric Windows / Remote Central Locking
Post by RGNEAVE »
I had a chat to a guy on ebay about this the other day as im looking at my rear windows
if its just the front you will be fine and they will fit i was garanteed 100% on this
The back is a diffrent question they told me that there would not be any space and that they will not attach to the window mec im taking my cards out the back this weekend to check
Hope this helps
On a quick note replacing the complete loom on the cabby is easy and would make a much better job but it takes a lot more work
Hope this is of help
214cab
Post by 214cab »
Loom easy to change you say? Is the loom in sections?
Ie is the engine bay seperate from the main car? If it is i'd consider doing it but don't much fancy ripping the wiring out of the engine bay complete!
I guess if i had a loom i could basterdise the missing bits into my current wiring.
RGNEAVE
Post by RGNEAVE »
Sorry ive had my car in that many bitts that many times
Yes its all sections can you tell me the year and ill check my wireing diagrams.
Ill pdf and email them to you if you would like
I went to a scrap yard and just got the looms i requiared took me a day to get the loom from the donnor car
Were are you located because i would be happy to help if posable
214cab
Post by 214cab »
mines a 1992/3 k reg 1.4 spi engine
i'm in dorset so a little way from you, i'll pm you my email address, if you get a moment wiring diagrams would be great
RGNEAVE
Post by RGNEAVE »
yer its a bit far
Ill get them by sunday as there not at my new house.
mach1rob
Post by mach1rob »
Front windows are easy to swap over for electric ones, rears, I'm afraid will have to remain on the winders.
For the central locking, it may be easier to just get a decent alarm system that includes remote locking, rather than a cheap kit I fitted a Toad system to our old 214 to enable remote locking.
214cab
Post by 214cab »
Thanks guys. The more i think about it i might try a standard install for the electric windows, as i have virtually all the parts bar the wiring in the car, plus i want to swap to electric mirrors too. (ie i've got the door looms, electric window control box and the winders (not 100% sure they are from a cabby though i assume standard 3 door r8 winders will work.))
I guess i need to find a scrappy who'll actually let me get at a car rather than want to take bits off for me!
mach1rob where abouts in Dorset are you? I live in Poole (work in Blandford)
Not that i'm fussed about the rears, i'm sure someone on here was looking at building a kit for it.
mach1rob
Post by mach1rob »
Trents will let you in, at a cost though! £1 last time I went few months back, just tell them you're after some interior trim :wink3
You may find the loom up to the A pillar includes with window wiring if you're lucky, meaning plug and play for the door loom.
Do you have the door switches too? Don't forget you'll end up with holes in the doorcard where the winder used to be, and you'll need to make holes for the switches.
Not 100% sure on the arm for the windows, I suspect they'll be the same, but the channel that attaches to the window may be shorter to allow for the cabby having the quaterlight, may need some jiggery pokery worst case scenario.
I'm other side of Bournemouth, so not too far from you.
S495KBL
Post by S495KBL »
I have done many a window conversion in my time. I would fit the standard ones in the front and just wire them up as an accessory and use the standard switch's etc.
You can get blanks for the door card and many are still in stock with Rover. Best ones to use are the later Rover 100 ones as there the correct colour.
Rear canbe done also, but tricky and not very reliable as the cable setup is very poor to start with and was not made for the torque of an electric motor.
