Remove / Change Gear Knob
214cab
Post by 214cab »
How do you change the gear knob? Mine is very worn so i'd like to replace it with an original one in better condition.
I assume its not as simple as unscrewing it since the lift for reverse is fitted with the gearstick etc.
Fatdave
Re: Remove / Change Gear Knob
Post by Fatdave »
lift reverse, is this in a rover :S normal rover gear knobs just unscrew. well unless its a 75/zt. lots of different ones from other models fit, i had am mg tf one in my 200
214cab
Post by 214cab »
In my 214 cabby. Have to lift a 'ring' under the gearknob to engage reverse.
It 'might' unscrew but without wanting to apply too much pressure (and risk breaking something) it did'nt budge a mm.
Post by E_T_V »
1.4 shouldn't have a lift to reverse. At least mine didn't!
Fatdave
Post by Fatdave »
the ring under the gear knob, its not just part of the gaiter is it. never heard of lift reverse on a rover
214cab
Post by 214cab »
I'll check again tomorrow i could be being stupid! I could swear it needs to be lifted.
carl747
Post by carl747 »
1.4 K R65 box ? never seen a lift reverse
it should just be a unscrew gear knob
64 1/2 Ford Mustang 289 V8
Past
94 Rover Metro Gti
03 MG ZT
89 Austin Metro 998
92 Rover 216 GTi Twin cam (Roversport Kitted) Twice :laughing2
97 Rover 218 VVC Cabriolet the original VVC Cabby (Roversport Kitted)
214cab
Post by 214cab »
I'm glad to report that i'm not mad, and also the gear knob itself does just unscrew just needed a little brute force.
But to engage reverse i do have to lift a 'ring' attached to the gearstick surround. I can take a photo if you're interested.
How can i identify the gearbox type / model? The engine is a 1.4 16v SPI if that makes any difference.
mach1rob
Post by mach1rob »
Very early ones had a lift to reverse, but I would have thought by the time the cabs came along they had all changed to the normal selector.
As seen here.
214cab
Post by 214cab »
Thats what mine is like.
Its a K plate pre-facelift cabby (1.4 16v spi engine)
