Power steering suddenly light - new rack or new pump?
tnj0133
Post by tnj0133 »
214 cab 1994 (M) registered 12/12/94 with pas.
Hi chaps, there is another thread on this subject but I can't tell from that thread if I should buy a new pas rack or if there is a pressure regulator in the pump I should be looking at. On the rimmer bros site, the new rack doesn't mention a pas or non pas part.
And in the haynes manual there's no distinction between fitting a pas or non pas rack either. Surely if the fault is with the rack, I would need to connect the pas pipes to the new rack? Confused :( !
Any help would be really appreciated
1994 214 Cabriolet
2007 Civic Type S GT
2006 CR-V Executive
Previous cars, '97 216 Cab, '94 214 SLi, '92 214SLi, '91 216 GSi, '87 213 SE
Re: Power steering suddenly light - new rack or new pump?
Post by richard moss »
If it's the same Rover rack as the 800 (or at least a similar design) then it is possible for it to suffer an internal valve failure in the rack making it go light.
PS: Rimmers list Power and Manual racks separately. Note: Honda engined cars use a Honda rack, Rover engined cars are different.
http://www.rimmerbros.co.uk/Item--i-GRID002756
tnj0133
Post by tnj0133 »
Hi Richard, thanks for the information - I've ordered a rack based on your info (part number) - really grateful for the help, I couldn't find the right part number.
I consider myself a novice DIY mechanic, servicing, replacing ancillaries etc. any opinions/tips on whether I should attempt the job of installing the new rack myself? I don't have access to a ramp but have a driveway and axle stands etc
1994 214 Cabriolet
2006 CR-V Executive
I've never worked on the rack on a 200/400 before. Changing one on an 800 isn't too bad - a bit will depend on how much of a novice you are. Hopefully someone on here can offer better advice.
tnj0133
Post by tnj0133 »
Ok, thanks again buddy
Anyone else had experience with changing the pas steering rack on a 214?
1994 214 Cabriolet
2006 CR-V Executive
Post by crepello »
tnj0133 wrote:Ok, thanks again buddy
Not the pas rack, but I did my manual rack about 3 years ago. Trickiest bit was persuading the track rod ball joints to part - needed heat from a blowtorch. Lifted the front of the car on stands, dropped the front end of the gear selector mechanism from the subframe, I forget whether I had to drop the front exhaust section, but I did drop the anti-roll bar. The rack has a saddle clamp towards the passenger side and two bolts through the pinion housing. The rack has to be shuttled from side to side to get the ends clear, as the subframe wraps round them. When the rack was out, I clamped it to a length of wood and accurately marked where the track rod ends were. I set the new rack up with the original ends to the same marks, except I didn't copy the half-inch off-centre the original rack had been set to.
You know what the reassembly involves - you said you had a Haynes book!
Mine was an afternoon's work.
tnj0133
Post by tnj0133 »
Phew, sounds like a bit of a job! Thanks for sharing your experience. Can you remember if it was more difficult than you expected or if it was relatively easy but just time consuming?
Thanks again
T
1994 214 Cabriolet
2006 CR-V Executive
It's not the easiest job but do-able with the right tools and a bit of know-how. Having 2 heads and 4 hands is a good idea too.
Getting the gear out of the gap in the frame is a bit of a brain-teaser - you have to have the rack on full-lock to get it out - but I can't remember which one....
Take care with all fixings in the beam (subframe) you don't want to strip one!
All R8 PAS racks are same - Hondas are no different - but obviously there are RHD and LHD versions
tnj0133
Post by tnj0133 »
Awesome, thanks GTiJohn :) I'll give it a go this weekend - weather permitting and post how I get on
T
1994 214 Cabriolet
2006 CR-V Executive
