hydralic clutch
derbylad
hydralic clutch
Post by derbylad »
hi i was wondering if anyone knows how to bleed the clutch on the rover400.has i need to replace my gear box and driveshafts.
Post by E_T_V »
The 400 wedge has a cable clutch? Is yours a later bubble?
If so then by far the easiest way to do it is via a vacuum bleeder. You can make your own if you are resourceful!
There is a bleed nipple on the slave cylinder. It'll become clear as you remove things to remove the box.
