New guy needs help!
adomakin
New guy needs help!
Post by adomakin »
Hi everyone, new here, managed to acquire an incredibly immaculate 1995 214sei 16v with just 11000 miles on the clock!
Has a 5000rpm idle issue though… so am here for your help
Thx in advance!
Andy
Re: New guy needs help!
adomakin wrote: Sun Aug 23, 2026 12:00 pm Hi everyone, new here, managed to acquire an incredibly immaculate 1995 214sei 16v with just 11000 miles on the clock!
Thx in advance!
Andy
5000rpm idle :o
Is the throttle stuck open?
Mechanically it could be the cable or the butterfly sticking. You can operate it by hand under the bonnet or get someone to press the pedal while you look and feel what happening.
If it's 'electronic', performing a throttle position sensor (TPS) reset might be a good idea. To do that:
1) key to Position 2
2) press throttle pedal fully down 5 (or is it 10?) times
3) listen for some 'whizzy' noises under the bonnet
4) ignition key back to 0
5) start car normally
Can somebody confirm if I've got this right pls ? :laughing2
The O.P need to tell us the build order, plastic or ally inlet manifold, because the throttle valve assembly is different.Also the E.C.U has differing part numbers.
