Heater hose....where to get one?
416tourer
Post by 416tourer »
Hi all,
My Tourer that I swapped for a 827 Vitesse has had a wee problem.
There is a hose that comes out from under the distributor and then goes over the heater valve has split and is no longer usable.
We have tried Rimmers, Rover NZ, and Honda NZ to try and locate a replacement hose. Apparently they are no longer available.
The Tourer has the D16A8 Honda motor in it (DOHC head) and I would assume that the hose is the same on the SOHC head Honda motor as well.
Does anyone know if there is anyone else in the UK who might stock them or can suggest a suitable replacement? Plus they need to be able to ship to New Zealand!
Cheers
Graeme
1990 Rover Vitesse 2.7 ltr auto, Pulsar Silver, leather
1988 Rover Sterling auto, 2.5 ltr (English private import) Shantung Gold/Grey
1986 Rover SD1 Van den Plas, auto (English assembled) 3.9 ltr engine, Cashmere Gold
Sir Henry
Re: Heater hose....where to get one?
Post by Sir Henry »
I've not done enough work on this part of my car's system to recall, but is this a shaped hose or just a plain one that is gently curved around to fit? If the latter then any heater hose of the correct diameter should be acceptable.
Vehicles currently owned (smallest first)
2002 Peugeot Vivacity 100cc scooter
1979/80 Suzuki 850 Trike Conversion
1995 Rover 216 twin cam (Honda lump) Cabrio
2004 Jag 2.5 X-type AWD Estate (manual)
1992 Dodge Ram 250 Day Van (3.9 V6, now on LPG)
Fatdave
Post by Fatdave »
replace it with silicone as ive been slowly doing on my 600. it wont be shaped but that doesnt really matter.
416tourer
Post by 416tourer »
Thanks for the replies, the hose is shaped......has 2 elbows and also a slight kink in the middle.
I think he is going to try and get to separate elbows and make a hose to fit.
Graeme
