Why unfortunatelly?
Well, I disconected the steering column from the rack in the footwell, but then found out, I took out the upper part of the joint-ball aseembly instead of the bottom one, so logicaly, the rack wouldn't wanna come out because of the extra extension. All good - but...I managed to forget about the fact I shouldn't turn these parts when disasembled - unfortunatelly, I turned the joint-ball assembly while it was off the steering column allready...I guess I'll deal with it later.
As for the subframe, can anyone tell me how heavy it realy is? Just so I can be prepared. I guess if I suport it with the hydraulic lift on one side while I work on the other might work? If not, I will of course get some help. Mine is rotten only on one side - the layer on the top (as far as I can remember its two or three layers at some points). But yeah, its the connecting part, the one that acts as a bridge where the beam is tightened into the chasis. I am taking it off just so I can sleep better. I will clean it, sand blast it in weld if / where, needed and protect it. Not sure yet how Im going to do all that due to stupid shape but we'll see
It really is a pitty to see such a great car with a design flaw that causes them to die before they should really...
