no heater
slisteve
no heater
Post by slisteve »
problem is engine temp gauge reads hot heater blows cold.
car ran normaly for 160 miles then gauge went up n heater blew cold i
im thinking thremostat
car is 1.6 honda engined auto
fiat 500 lounge 1.2 dualogic BF63TXS
rover si auto L524WLE
slisteve
Post by slisteve »
ive changed thermostat & its still the same.
due to go to blackpool monday so ill overall cooling system when i get bk
new water pump ect & itl give me chance to change timing belt at 54000k its more than due & if head gasket needs to be done ill do that aswell mite even write an article for club mag
meanwhile if anyone has any ideas
my bro will check for replys.
Smithy
Club President
Post by Smithy »
Hi,
I don't know too much about the honda engines, but I know on our old diesel when the heater ran cold whilst the engine was warm it indicated head gasket failure (may not be the case for the honda).
If you do change it an article for the club magazine would be fantastic. :)
Rover 220 GTi Turbo.
Post by E_T_V »
Check the simple things first. There is a valve that controls the flow of hot water into the heater matrix. It is controlled by a little wire that is connected to the knob in the car. Check that the valve is still opening and closing and that the wire is still attached.
slisteve
WORK
Post by slisteve »
work has started on fixing problem ive removed radiator, n hoses cam cover & manifold head will be off next.
work thats being done
new rad
timing belt
head gasket & assoiated gaskets, seals ect
compleat headset off ebay 30.00 plus 10 postage :D
itl also have new oil n filter & service
an article will be writen for magazine
looking at about a week with cleaning & painting of bits n bobs
looking fward to many miles of happy motoring :clapping
Smithy
Club President
Post by Smithy »
article for magazine sounds fab look forward to recieving it :D
woodsy_mv6
Post by woodsy_mv6 »
Only sounded like heater matrix to me
SHOOT THE PHOENIX FOUR; THE TRUE ASSASSINS BEHIND ROVERS DEMISE!! :glare
'99 Omega 3.0 MV6
'94 Rover 420 GSi Turbo
'85 Monza 3.0 12v GSE
'93 BMW 750iL
'04 Audi A2 1.4 TDi 90
'54 VXR220
slisteve
Post by slisteve »
wish it was
was loosing water no external leaks
steam from exhaust
romoval of cam cover confirmed head gasket gone
milky sludge in cover.
if cam covers sludgey sumps gota be cacked in it il take it oiff aswel &| clean
ive started a write up so ul alll be reading in club mag
slisteve
Post by slisteve »
ive now done 850 miles since changing headgasket a job wel done ive sent article to mag reletivly straight fward job runs a lot better aswell
woodsy_mv6
Good to hear you got it sorted :cool
'99 Omega 3.0 MV6
'93 BMW 750iL
'54 VXR220
