timing
timing
hi wanting the timing marks of a rover 220 turbo has anyone got them and where they should be thanks chris
got the timeing marks but still having this problem
the engine turns over as normal after turning over for about 5 spins it goes slow for a turn or tight as you might describe it then back to normal speed eventually after a few times of that it just about starts but runs a bit rough, if i take the coil leed of it turns over fine as many times as you like.
Stolen from elsewhere on the interweb from MGJohn so all credit goes to him.
First picture:
The above illustration shows the crankshaft pulley index in the 9 O'Clock position. Then, pistons Nos. 1 and 4 will be at 90 degrees BEFORE TOP DEAD CENTRE and pistons Nos. 2 and 3 at 90 degrees AFTER TOP DEAD CENTRE. All four pistons will be at the same level in the cylinder bores. When 'timing' the engine prior to fitting the timing belt, that crankshaft index must be set like this.
Picture 2:
The INLET CAMSHAFT PULLEY (on the left) and EXHAUST CAMSHAFT PULLEY (right) need to be in this position. However, it's not as simple as that because there are TWO slots on the camshaft pulleys- see next pictures - and the correct slot must be selected..
Picture 3:
LHB10028 - EXHAUST PULLEY with its locking bolt removed to show that the slot marked 'EX' must be located over the roll pin.
Picture 4:
Again with bolt removed, INLET PULLEY LHB10029 with the Roll Pin located in the slot marked 'IN'. The roll pin is difficult to see but is in the slot marked "IN" if you look closely.
Picture 5:
This is how they should look with the timing belt in place and the CRANKSHAFT PULLY INDEX still showing the 9 O'Clock position - see Picture 1.
WARNING Before starting that engine, DOUBLE CHECK AGAIN that CRANKSHAFT pulley index is still in the 9 O'Clock position.
Pictures taken of the engine in my 1993 TomCat Turbo.
First picture:
Picture 2:
Picture 3:
Picture 4:
Picture 5:
