my cabriolet
Re: my cabriolet
Post by ROVER Cabby »
What does yours need doing to it Disco to get it back on the road ? :wink3
discodude
Re: my cabriolet
Post by discodude »
hi,m.o.t ,full service ,oil leak sorting and head gasket is weeping!.
regarding the oil leak, when I had it first looked at they said new cambelt and seals.
these were fitted, but after about a week it was still leaking.
they fitted a new belt and seals free of charge, then said my head gasket is weeping.
I still had an oil leak, so back it went, they now say I need new cams!?
this was also free of charge.
I was told I can still run the car, but I just need to keep the oil topped up, this is when I decided to sorn it.
I also want/need two dents pulling out,alloys re furbed,rear spoiler {coupe} blowing over,3 rust patches sorting and chrome inserts re placing.
it will get sorted, just don't know when.
Re: my cabriolet
New Cams ?
Doubtful, they are made of pigiron, probably needs Cam Seals.
discodude
Re: my cabriolet
Post by discodude »
hi, its already had 2 sets of seals and its still leaking.
when money aint an issue I will get a 2nd opinion.
thanks
anchor
Re: my cabriolet
Post by anchor »
That looks lush - it is singing to me.
Re: my cabriolet
Post by itcaptainslow »
Wonder if they’re fitting the cam seals the correct way around-if they’re not fitted with the correct rotation in the correct positions, they’ll leak badly.
Get them to use genuine seals too-I’ve found aftermarket ones are rubbish and quite often don’t have the little raised rubber lines in them to aid sealing.
Re: my cabriolet
itcaptainslow wrote: ↑Tue Nov 19, 2019 9:48 am Wonder if they’re fitting the cam seals the correct way around-if they’re not fitted with the correct rotation in the correct positions, they’ll leak badly.
Need to recognise there are brown ones and black ones both are for different locations.
Re: my cabriolet
Post by Paul_1978_yorks »
The original post is nearly 3 years old. The car is no longer taxed or MOT’d and is not on a SORN.
Re: my cabriolet
This sounds familiar, AKA mine. :slapme
