Aftermarket Immobiliser
Julesmat50
Post by Julesmat50 »
Not a Rover issue, but this forum seems a font of knowledge, so I will ask and see if anyone can help.
My father has a Suzuki which before he got it, had been fitted with an aftermarket alarm/immobiliser (I assume as the car has a remote key access it was added to give the car extra security). In common with a lot of fobs, one of them has totally disintegrated so he now only has one that works, which worries him as if for any reason he has an issue with this fob, he will be stranded. I can get him a spare, as there are some on Ebay, but they are second-hand ones. How easy will it be to get a secondhand immobiliser fob to work with my father's car?
Were it one supplied by the manufacturer, I could get it synced from the local dealer, but as it's an aftermarket one, does anyone have any suggestions?
Re: Aftermarket Immobiliser
As shitzuki are still alive, any dealer shout be able to program the fob and rip you off accordingly. Don’t be surprised if bills are £70+
Post by JOHNDQ »
Is it a Cobra unit?
214 Sprint track car
216 GTi track car
216 GTi DOHC
Post by Johnny 216GSi »
Julesmat50 wrote: ↑Thu Feb 08, 2018 12:39 am Not a Rover issue, but this forum seems a font of knowledge, so I will ask and see if anyone can help.
If it's aftermarket, then there should be instructions that accompany the alarm that show you how to pair new keys with it. Cobra units have this ability, for example.
If you know the make and model of the immobiliser, it would help as you can then get in touch with the manufacturer or possibly find the manual online.
If you can't find syncing information, can you buy a complete alarm system and fobs - the same or second hand? Provided you do a like-for like cut-and-splice of the wiring between the existing and replacement alarm, it should work without problems. Problem is, the second-hand unit won't have wiring information with it - they just have a set of innocuous black wires coming out of the box so finding one where the person that's removed it has labelled all the wires might be difficult. If I've got all the wiring information I need and I'm splicing in a replacement, I tend to tape a piece of paper with a number key to the wires - matching numbers each side of any cut I make so I never get into a mess.
Other options include:
1. Since you have 1 working key, you can arm and disarm the unit and this makes tracing the wiring function much easier. You can find the immobilised circuits and feeds for alarm trips such as the door switches. At this point, you can cut the unit out and replace it with a new one which does everything you want it to. All alarm/immobiliser systems work on the same basic principles, so they should be interchangeable provided you know what the existing wiring does. They all need a 12v permanent feed, ground, a switch 12v line to hold the alarm/immobiliser off when the vehicle is running. Then they just need feeds from door switches, lights, etc. that either switch to ground or +12v when triggered. Immobilisers just break electrical circuits, so if you can arm/disarm the existing alarm and find out using a multimeter which pairs of wires are being connected together/disconnected by the relays in the immobiliser, these can simply be attached to the normally open immobiliser contact sets on the replacement unit.
2. If the second fob has failed just because the case has fallen appart, you should be able to find a spare case.
3. If the 2nd fob basically works but the buttons only work if you press them very hard dozens of times, it would be possible to find replacement buttons and solder them in.
Julesmat50
1234dist wrote: ↑Thu Feb 08, 2018 7:38 amAs shitzuki are still alive, any dealer shout be able to program the fob and rip you off accordingly. Don’t be surprised if bills are £70+
This would make life a whole load easier albeit expensive, but regrettably it's an aftermarket system, so like Jon Snow "they know nothing" :D
JOHNDQ wrote: ↑Thu Feb 08, 2018 8:53 amIs it a Cobra unit?
It's a GT Auto Alarms system. Apparently it's an Italian company, which with the reputation that Italian electrics had in Italian cars, probably explains why the fob is in bits! :laughing2
Johnny 216GSi wrote: ↑Thu Feb 08, 2018 11:45 amIf it's aftermarket, then there should be instructions that accompany the alarm that show you how to pair new keys with it. Cobra units have this ability, for example.
He has the instructions for pairing the fobs, but if I get a fob for him it won't be a new unused one (these are completely unavailable even from the supplier of the system) but secondhand, which means it's already been paired with a unit. Would this make any difference?
The unlock/lock microswitch inside the fob (there is no separate button for each action) has broken off completely from the circuitboard and is in 3 bits!
At the present time, there seems to be 3 options on how to proceed in ascending order of cost -
1. Get a secondhand one and hope it can be synced (about £25)
2. There seems to be a few places that claim to be able to repair the existing fob for about £70
3. Get an autoelectrician to remove the system entirely and go back to just the remote locking without any immobiliser.
Julesmat50 wrote: ↑Thu Feb 08, 2018 9:06 pm
I don't think the fob knows anything about what units it's been paired to. It's the alarm/immobiliser than remembers the keys.
Even if it's a rolling code (it won't be) the immobiliser should pick it up and the key won't know anything! I'd go as far as to say you can pair a key with multiple immobilisers at the same time. Provided the rolling code algorithm looks either side of the curren code for a few "acceptable" codes either side, I bet you can use the same key with several paired immobilisers.
If you upload a photo of the broken fob, I might be able to point you in the direction of a replacement switch if you're a dab hand at soldering...
If you posted it to me and it was only a switch replacement, provided we can find a replacement switch/button, I should be able to do it.
Last edited by Johnny 216GSi on Thu Feb 08, 2018 9:21 pm, edited 2 times in total.
might be easier and cheaper to get an auto electrician to rip it all out, last one i had came at about £40.
Julesmat50
Johnny 216GSi wrote: ↑Thu Feb 08, 2018 9:11 pm If you upload a photo of the broken fob, I might be able to point you in the direction of a replacement switch if you're a dab hand at soldering...
Here are couple of pics of the offending fob :D
https://ibb.co/i8iFqc
https://ibb.co/cJxfOx
I "think" the microswitch is meant to connect the 2 blobs of solder between the black chip and the items labelled 101 and 102
And thanks to the ominpresent Dist for uploading these before I could blink! :angel
Replied to the OP's PM now. Will look at trying to fix this (perhaps...)
