Engine wiring
Xtrmjks
Engine wiring
Post by Xtrmjks »
Hi, anyone have a list of what is the minimal number of wires, to get 1.4 8v rover engine running? Using one of these in a kit car..
Re: Engine wiring
Post by JOHNDQ »
1.4 8? You sure it's not a later MEMs 3 engine
214 Sprint track car
216 GTi track car
216 GTi DOHC
Roverlike
Re: Engine wiring
Post by Roverlike »
1.4 8valve engines were available with MEMS 1.9 as I have one ioriginaly n my car, and I am not sure if they were available with MEMS 1.6.
Xtrmjks
Re: Engine wiring
Post by Xtrmjks »
No idea what version MEMS it has. Engine code is 14K2FK43.
Re: Engine wiring
Post by JOHNDQ »
Ok so what ECU will you use using. Do you have any pictures of engine
216 GTi track car
216 GTi DOHC
Xtrmjks
Re: Engine wiring
Post by Xtrmjks »
It’s ecu, with separate black box (rover immobiliser?), this has been bypassed, as fuel pump primes and ecu is “alive”?
Xtrmjks
Re: Engine wiring
Post by Xtrmjks »
Just checked, ecu is Rover M.E.M.S, mkc103400, crank sensor has ac voltage to ecu plug. No spark..
Roverlike
Re: Engine wiring
Post by Roverlike »
That is MEMS 1.9 from Rover 114 GSi 1.4 litre engine.
Re: Engine wiring
Post by JOHNDQ »
So what's the problem you have no spark?
216 GTi track car
216 GTi DOHC
Xtrmjks
Re: Engine wiring
Post by Xtrmjks »
Yes, no spark. Wiring checked, coil checked. Fuel pump primes, have fuel pressure, coil has feed, ecu not switching the coil.
