Rear Light Cluster Leak
4V8s
Re: Rear Light Cluster Leak
Post by 4V8s »
I have had pretty much all these causes, but the main one I have struggled with is the boot seal.
If the catch doesnt pull the boot shut pretty tightly (on hatchback) I get water leaking in high up in the area above the boot interior light on both sides.
so if you have this issue you can try and adjust the boot latch to close tighter and see if that helps
Rover 214Si 16v 1994
Rover 220 turbo coupe 1995
Rover Mini Cooper 1997
MG ZT 260 V8 SE 2004 - OK, so another Rover
1967 Ford Mustang 289 V8 convertible
1974 Corvette Convertible 350 V8
1977 Pontiac Firebird 403 V8
Post by Topcat Tomcat »
I have a leak in the boot of my 1990 216 5 Door. I thought that I had sorted it by re-sealing the boot vent.
Unfortunately, a small amount is still getting in. It appears to be running down the air outlet duct, onto the boot vent and down onto the floor. The trouble is, I can't work out where the initial leak is.
Does anyone have any suggestions?
Vinny1979
Post by Vinny1979 »
i have the same issue
Did the side vents some years ago.
Will get round to it in the spring :laughing2
If you find the source before I do, please let me know!
RetroRacer
Post by RetroRacer »
I have this mysterious wet boot issue too...
I was in the boot all afternoon yesterday after detailing the car.
All areas mentioned above are bone dry... apart from the area around the base of the vent on the passenger side. I assume this is just down to condensation and there is not a lot I can do about it :glare
1994 L reg 216 SLi
