Erratic Fuel Guage.
Stan Thomas
Erratic Fuel Guage.
Post by Stan Thomas »
The only disconcerting thing about my 420GSi is the erratic fuel guage - which I'm told is a commom "feature" of the Rover 400 range.
If so, is there nothing which can be done or no modification as yet devised? On the otherhand, if my fuel guage sender is faulty - do I really have to remove the fuel tank to get to it?
Over 20 litres the guage drops from 3/4 full to almost empty - then stays there - but for how long before I run out?
All I can think of if nothing can be done is to drive until the fuel warning light comes on, (and carry some fuel in a container to initally test it in case that too is faulty). That way, at least I'd know my remaining range. Any ideas lads - or at least can you tell me how much fuel do I have left when the warning light comes on?
See you at Gaydon now the mortgage has come through for the fuel.
Regards to all,
Stan.
Re: Erratic Fuel Guage.
Are we talking about a R8 here or the latter car Stan?
I can't say I've noticed any difference on a R8 Because the fuel system etc is identical! Even on empty there is at least a gallon plus in the tank. Not a good idea to drive around on empty because the swirl pot arrangement of the fuel pump uses fuel to cool the pump.
My experience is that the gauge sticks on 1/2 full, then drops quickly to 1/4 but I've never found it an issue.
If it registered 1/4 and ran out that would be a problem!
Stan Thomas
Thanks for your reply - and you've got it spot on!
My fuel guage quickly decends from half full to nearly empty - then stays there. Once I've confirmed the fuel warning ligh works I can treat the guage accordingly, based upon a reasonable average M.P.G. which at the moment I use as 30 M.P.G. being the 2.0 litre engine. Other than that I find it a very pleasant car to drive, and much better than my daughter's £34K flying fusebox.
One aspect of electric cars which seems to be overlooked is that considering their accelerating technical development, her car will be obsolescent in just a few years time with a residual value of almost diddly sqat. Daft as it seems, properly looked after my Rover will one day be worth more than her Lexus. Howsabout that for depreciation??
Regards to all,
Stan.
JEASPEKE
Post by JEASPEKE »
If it is the same as an R8 Tank, and R8 body, you can access the fuel sender unit from below the rear seat, remove the circular panel and that will reveal the sender unit connections. Top Right here>
Disconnect the battery first and be aware of fire risks with an open tank. the sender unit can be tapped with a screwdriver 1/3 turn anti-clockwise and removed, check seal, seating etc, and be careful of dripping fuel.
Mine was rusty but managed to get it operational again with WD 40 then let it dry and refit with a new seal if possible (think I got one from Rimmers). Check connectors and cables too that may be the source of your problem
Stan Thomas
Thank you Jeaspeke for your most informative advice and pictures.
However my car is an HHR type and according to the Haynes Book of Lies, the fuel guage sender is part of the fuel pump and it says you have to remove the petrol tank to get to it.
Any road up (as we say in Bermingum) you could well be right - so Ill certanly look into it.
Thanks again for your help.
Stan.
No simple fuel sender [ basically a variable resistor] fitted to mass produced vehicles fuel tank is going to give a linear output at the gauge.
So unless it stops working or reads 1/4 full when you've run out, I would leave well alone. :)
Stan Thomas
Good point "Teddy Bear" !
However, purely on a technical note - given the fuel guage sender is a variable resistance - - when the ignition is tuned off the needle should return to zero as in all other cars as I recall - whereas on my model Rover it continues to remain registering the amount of fuel in the tank?
Roverlike
Post by Roverlike »
In all MG-Rover cars I had, viewed or worked with (1990 - 2005) have needle that points the amount of fuel in reservoir when ignition is off. It is speciality of MG-Rover.
Roverlike wrote: ↑Tue Jul 05, 2022 4:47 am In all MG-Rover cars I had, viewed or worked with (1990 - 2005) have needle that points the amount of fuel in reservoir when ignition is off. It is speciality of MG-Rover.
None of mine have! only car where the gauge stayed live was a Mitsubishi Colt.
Julesmat50
Post by Julesmat50 »
Curiously I have one of each. My facelift 95 Rover has the fuel guage drop to zero when the ignition is turned off (as did my fathers, who also had a 95), whereas my 96 Tourer has a fuel gauge that remains fixed at the approximate current level when ignition is off. :D
