216gti tailgate misaligned/higher than roof
Re: 216gti tailgate misaligned/higher than roof
1989 216GSI + 1990 216GSI + 1997 416 Tourer + ? + Triumph T160V
- RoverRevival
i bet that lets a bit of water in as well doesn't it.
- Contact:
Ooof- I don’t like the look of that
Hopefully you’ll get it sorted.
Looking at your pic I would say the hinge mount is raised. With the tailgate up is the hinge flat to the body where it mounts ? It should look like the correctly fitting side.
There are many reasons a tailgate will kick up like that from rear end shunt to blowing up with a strong wind. I've seen worse in my past bodywork life.
Obviously without seeing it in the flesh I can only guess, but i would suggest the best way is tailgate off and knock the panel back down using a hammer and block of wood.
Hope this helps.
Hope this helps.
I have had this on a car that has lived outside all its life. like someone said earlier its almost certainly a bent hinge as a result of it becoming seized. If you have a replacement one they are not that much trouble to replace pretty much in situ but you need someone to help you hold the boot lid whilst the operation is happening.
Twin G reg Red 216GSi Rovers
