Air in diesel filter
R8SRGR8
Re: Air in diesel filter
Post by R8SRGR8 »
The L series diesel seems like a good swop and a lot quieter than my XUD7. Thanks for the info. As far as the air leak is concerned have now sorted it and am embarrassed to say it was simply the top seal on the fuel filter had twisted and got pinched. Hey Ho alls well that ends well new seal fitted and no more air in fuel. Now have a problem with the turbo which is throwing oil into the air intake pipes from the intercooler so I think a serious change is beckoning. Any tips for the L series swop would be greatly appreciated. :clapping
Russnp
Post by Russnp »
You could ring CJL tuning in Spalding a bit far from you but he may be able to do the job for you as he's a rover specialist
98 Rover Coupe VVC
99 MGF VVC
03 ZT 135
03 ZR 115 TD
15 MG3 , partners car
Off the road at present
Maestro van , British Rail
Maestro EFi - in body shop
Metro Turbo
R8SRGR8
Post by R8SRGR8 »
After much researching and thinking with a beer at hand I have finally sorted the oil issue. It turns out that despite the previous person who replaced the turbo saying that all air related items had been cleaned when the new turbo was fitted it turns out that the problem was in the intercooler which was thoroughly clogged with oil and sludge. I have removed this as well as all the air pipes and breather given them a thorough degreasing, wash and dry and refitted to car which is now running great with no apparent oil blowing from the turbo. Job done. Should have done the job myself in the first place. Lesson learned. :clapping
richard moss
Post by richard moss »
You should be able to crank up the boost and fuelling to increase power - there must be Peugeot/Citroen forums that can help with how to do It (it's generally feasible).
Out in the desert with an old Jeep and a Volvo.
Back home: wife's 1993 216 DOHC Cabriolet, daughter's 2002 R25 and my 1969 MGC GT
R8SRGR8
Post by R8SRGR8 »
Thanks for that I'll see what I can find on the citroen/peugeot forums then.
R8SRGR8
Post by R8SRGR8 »
Before I ended up spending more money and considering I cleaned out the intercooler etc I thought I would try an Italian service. That did the trick and I have now regained the power I thought I had lost. Thanks for everyone's input. :clapping
Post by RoverRevival »
Now get it mapped :wink3
