Head lights
Re: Head lights
Post by StubbornPatriot »
Then yours may be different. I'm referring to its position on a 1989-95 R8. I've taken some pictures but the image hosting website is under maintenance this evening. I'll put the pics up as soon as I can.
Perhaps someone with an HHR can give you further guidance for your model. Sorry, I have no idea if it's in the same place.
1989 216GSI + 1990 216GSI + 1997 416 Tourer + ? + Triumph T160V
Roverlike
Re: Head lights
Post by Roverlike »
There is no relay in case of Rover 45 from year 2000. Power goes from battery to switch to fuses under steering wheel and to lamps.
MattJonesOne
Re: Head lights
Post by MattJonesOne »
Update for anyone facing the same problem in a Rover 45! Issue fixed. Required a new indicator/headlight switch. i.e. the stalk unit. £28 on eBay and about 20 minutes to swap around
