I've got one of these fitted to my car:Paul_1978_yorks wrote: ↑Sun Nov 07, 2021 1:05 pm I was thinking of getting some quick release battery terminals, as I’m likely to be taking my negative terminal on and off through the winter to save the battery when the car is out of use for periods.
I wondered if anyone had used them and had any thoughts.
https://www.ebay.co.uk/itm/124162582873
Take the bolt out of the "output" terminal, and the post is the same diameter as the post on a standard battery, so you just attach your negative wire here and clamp up as if clamping to the battery.
The isolator function is just a turn of the black knob anti-clockwise until it feels loose. To reconnect, turn the knob clockwise until it feels tight (and be ready with your key or alarm fob if the alarm goes off after reconnecting...!)
No wiring modifications needed and it's really quick to fit.
The *only* caveat is that you need to make sure the knob is quite tight when reconnecting the battery. I've had one incident (only one mind, in several years of having this fitted) when I tried to start the car having tightened the knob and it just died as if the battery was flat. It was just that I hadn't given it a decent enough tighten. It's been fine ever since and it's been fine for years now.
Recommended for the winter, definitely. I used to take my battery lead off with a spanner but you can end up rounding off the nut on the clamp. Plus, if you do need to go out in the car, it's really easy to just pop the bonnet, turn the knob, drop the bonnet and get in... hardly any inconvenience at all, really.
