Which things will kill our cars? Common faults?
Post by Mr Teddy Bear »
I'll phone them up on Monday :)
g259fsg
Post by g259fsg »
I expect the Honda engine alternator is an industry-standard type used on several different cars from that era, so spares for it are probably available to fix common faults such as the brushes/regulator or rectifier assembly. Have you been able to find equivalent part numbers from suppliers like Bosch or NAPA? The K-series (214) uses the Lucas A127 or equivalent and there are loads of electrical spares available for it. If the bearings have gone, then it's a bit more involved to repair it. I've reconditioned several alternators for our 214 over the years.
As a last resort, it's likely any 75A 12V alternator will work but you might need to modify the mounting slightly. Also need to check the direction of rotation. I assume the alternator is self-regulating and not relying on the ECU for that function as quite a lot of modern cars do. I can see that would be problematic if the Honda engine is designed that way.
Cheers,
Hugh
1990 Rover 214 GSi (VIN 222977)
1964 Humber Super Snipe Series V
1965 Humber Sceptre Mk.1
1966 Hillman Minx Series VI
Plodder
Post by Plodder »
I brought the brushes for my 1991 416 Rover from this company.
https://wagendass.com/en/
Yes they are in france so p+p and import tax add to the cost. But their cross ref chart meant I could identify my alternator exactly and the appropriate brushes. I could have brought then on eBay for a little bit less but I was reliant on the seller telling me they would fit on
1991 Rover 416 GTi Auto - Flame Red - Owned since Aug 97 :)
Thanks for tasking an interest! :D
The original according to Haynes is a Nipon Denso but doesn't give a manufacturers part number. The fault is unusual, a battery short circuit to earth that kills a new battery in 4/5 days. It took 0.5 V out of a spare battery in a couple of hours. I'm assuming that is the alternator diode pack that does the rectification going partly short circuit.
I'm going to try these people in Essex tomorrow.
Right a follow up to tidy the thread up and bring it to a conclusion! a happy one :D
The alternator that was taken off was as follows;
BOSCH 0 120 485 050.
KC - 14V 32-60A
31100-PP4-E03
Next to the barcode is 60/4
The service and communication from Guys Auto Electrics in Essex was first class. The old unit required complete refurbishment, Guy tested in on his rig on completion and supplied a test data sheet on return. The cost was approx' £312 inclusive of return postage.
Guy will also rebuild other N/A electrical vehicle equipment if you send a photo. That allow's a judgement on repairability.
Salifus
Post by Salifus »
Just to wrap this up on a happy note! The alternator removed was a Bosch 0 120 485 050 (KC - 14V 32-60A / 31100-PP4-E03).
Huge thanks to Guy's Auto Electrics in Essex—first-class communication and service. Guy fully refurbished the unit, tested it on his rig, and supplied a full test data sheet upon return. Total cost was approx £312 including return postage.
Managing build logs, parts, and service schedules on LOG2CAR.
