Page 3 of 6
Re: Plans or projects, Car or othersiwe for 2018 ??
Posted: Fri Jan 19, 2018 9:36 pm
by Aaronrover214cab1993
I don't do body kits but I'd make the exception for this
Posted: Fri Jan 19, 2018 9:44 pm
This was how the holy one kicked the doors in of the Rover community.
Sod your feeding of the five thousand, we’re off to maccy d’s, if I can get over the speed bump.
Posted: Sun Jan 21, 2018 2:06 am
by ROVER Cabby
If your too much of a snob to park up in maccies for a coffee then don't roll with us.
Posted: Thu Jan 25, 2018 8:25 pm
Aaronrover214cab1993 wrote: ↑Tue Jan 16, 2018 7:31 pm
My plans are fit new shocks and springs all round
New drilled and groved disc all round
Polybushes all round will be speaking to dust on this one when ready
also stainless coolent pipes and silicone hoses
Rear quarter and cill repaired
Full respray including wheels
Fit new Astra seats
Convert to a turbo 1.4
Full stainless exhaust
And all the nigeleu bits
I don't think I'll make pol this year but definitely next
Change of plans just brought a amaranth purple vvc coupe had front end damage so will be breaking it I'll be having the running gear gmax shocks and springs zs 180 brakes , exhaust and rear adjustable arms the rest is available panel damage is front bumper , bonnet , lights and drivers wing the rest is ok also has half leather trim
Posted: Thu Jan 25, 2018 11:51 pm
by Paul_1978_yorks
ROVER-25X wrote: ↑Fri Jan 19, 2018 7:59 pm
What is the clock doing Paul ?
Keeps going on and off and resetting itself back to 1.00am, often when going over bumps. Either a loose connection or dry joint I reckon.
Posted: Fri Jan 26, 2018 11:42 pm
by Johnny 216GSi
Paul_1978_yorks wrote: ↑Thu Jan 25, 2018 11:51 pm
Loose power connections. 4 pins on the back I think - ground, permanent live, switched live and "lights on" dimmer. At worst, the first 3 loose will cause all those problems and at best it's either of the first two loose.
Posted: Fri Jan 26, 2018 11:45 pm
by Paul_1978_yorks
Cheers Johnny - will take a look this weekend when I swap the wooden dash trim over from the parts car
Posted: Sat Jan 27, 2018 2:49 pm
by GTiJohn
The coupe's going to get a bit of love this spring/summer with some new front struts to make sure the MOT doesn't mention them again.
It'll also get fluids change - brake, gearbox oil & coolant - and a fuel filter if I can finally get the pipe nut loose
In addition to all the usual service items.
And I'll hopefully get round to fitting the shortshift gearlinkage (also courtesy of 1234dist) with a rebushed selector yoke to firm up the gearchange.
Posted: Mon Jan 29, 2018 6:19 pm
by ROVER Cabby
Get some pictures up of the new parts mule Arron.
Posted: Mon Jan 29, 2018 7:41 pm
ROVER-25X wrote: ↑Mon Jan 29, 2018 6:19 pm
Here we go again I'll try and remember what I done the last time and dist or who can do it will have to work there magic plus it's got the back lights
although I need to polish them and a very light tint to
