Plans or projects, Car or othersiwe for 2018 ??
Aaronrover214cab1993
Re: Plans or projects, Car or othersiwe for 2018 ??
Post by Aaronrover214cab1993 »
1234dist wrote: Fri Jan 19, 2018 9:07 pm always replicated but never bettered :rolleyes
I don't do body kits but I'd make the exception for this :D
This was how the holy one kicked the doors in of the Rover community.
Sod your feeding of the five thousand, we’re off to maccy d’s, if I can get over the speed bump.
Post by ROVER Cabby »
If your too much of a snob to park up in maccies for a coffee then don't roll with us. :*laughing my fat rear end off*
Aaronrover214cab1993 wrote: Tue Jan 16, 2018 7:31 pm My plans are fit new shocks and springs all round
New drilled and groved disc all round
Polybushes all round will be speaking to dust on this one when ready :tt2 also stainless coolent pipes and silicone hoses
Rear quarter and cill repaired
Full respray including wheels
Fit new Astra seats
Convert to a turbo 1.4
Full stainless exhaust
And all the nigeleu bits
I don't think I'll make pol this year but definitely next :D
Change of plans just brought a amaranth purple vvc coupe had front end damage so will be breaking it I'll be having the running gear gmax shocks and springs zs 180 brakes , exhaust and rear adjustable arms the rest is available panel damage is front bumper , bonnet , lights and drivers wing the rest is ok also has half leather trim
Post by Paul_1978_yorks »
ROVER-25X wrote: Fri Jan 19, 2018 7:59 pm What is the clock doing Paul ?
Keeps going on and off and resetting itself back to 1.00am, often when going over bumps. Either a loose connection or dry joint I reckon.
Post by Johnny 216GSi »
Paul_1978_yorks wrote: Thu Jan 25, 2018 11:51 pm
Loose power connections. 4 pins on the back I think - ground, permanent live, switched live and "lights on" dimmer. At worst, the first 3 loose will cause all those problems and at best it's either of the first two loose.
Cheers Johnny - will take a look this weekend when I swap the wooden dash trim over from the parts car :)
The coupe's going to get a bit of love this spring/summer with some new front struts to make sure the MOT doesn't mention them again.
It'll also get fluids change - brake, gearbox oil & coolant - and a fuel filter if I can finally get the pipe nut loose :headbanging
In addition to all the usual service items.
And I'll hopefully get round to fitting the shortshift gearlinkage (also courtesy of 1234dist) with a rebushed selector yoke to firm up the gearchange.
Get some pictures up of the new parts mule Arron. :thumbup1
ROVER-25X wrote: Mon Jan 29, 2018 6:19 pm Get some pictures up of the new parts mule Arron. :thumbup1
Here we go again I'll try and remember what I done the last time and dist or who can do it will have to work there magic plus it's got the back lights :clapping although I need to polish them and a very light tint to
