Social Isolation jobs list on the R3 Vi
Done anything to upgrade or personalise your club car? Wanting some advice on upgrades? Then talk about it in here.
Re: Social Isolation jobs list on the R3 Vi
Finally got to do the front brake swap back to standard - the hold-up was finding a local DTI.
So the original "14inch" front discs and calipers have been put back on the car. They were removed early on in the cars life and hardly have any wear on them.
The DTI was used to check that the run-out was minimised by the position of the disc relative to the hub
They replace the MG ZR "15inch" brakes and allow for the fitment of the original wheels
The 2 pairs of calipers used the same pads so I'm bedding them back in now.
I like Twin Cams, Single Cams, Turbos and 5-cam VVCs :cool
Montegoman
Post by Montegoman »
It looks soooo much better on the original wheels.
214SLi H706JPJ (11 yrs of ownership)
214GSi G79XKV (R8 No.1) (10 yrs of ownership)
25GSi 2.0TD KX56KXM Owned from new.
75 2.5 Connoisseur SE Tourer (21 yrs of ownership)
Montego Countryman 2.0i (Back where I belong!)
Post by Johnny 216GSi »
montegoman wrote: Wed Aug 05, 2020 10:27 am It looks soooo much better on the original wheels.
Indeed. People who mod cars don't realise just how much money motor manufacturers spend on cosmetic design and appearance. If making something look "better" was that easy, there'd be loads of "coach builder" type companies still around and supported by the vehicle manufacturers themselves.
Every time you put a car back to original a lightbulb moment occurs - an instant recognition that the mod you did was really just so your car could look different or "be the best." Original is best!
Johnny 216GSi wrote: Wed Aug 05, 2020 11:54 am
I've been surprised and pleased how much I like this look :laughing2
Post by itcaptainslow »
100x better on the original wheels!
216secoupeessex
Post by 216secoupeessex »
Any chance of an idiots guide how to on the gear stick gaiter replacement?
I need to do that on my late model coupe and got stuck when it came to taking off the dash round the radio
216secoupeessex wrote: Thu Aug 06, 2020 2:17 pm Any chance of an idiots guide how to on the gear stick gaiter replacement?
The Haynes manual covers it pretty well but simply, and as far as I can remember, it goes something like this:-
1. Remove rear centre console - remove rear ashtray and small access panel under handbrake lever to access screws (if you've got the armrest/high centre console you might need to take the cassette/CD tray out from inside the console) The rear fixing just need loosening, nor removing completely as the console slides off them.
2. Remove radio and disconnect harness connectors
3. Unscrew gearknob from lever (anticlockwise)
4. Remove 4 screws by front occupant's feet - 2 each side of the front part of the centre console
5. Carefully prize out upper part of centre console around top row of 5 switches
6. Disconnect harness connectors to switches and cigarette lighter
7. Put car into 2nd or 4th and withdraw console to rear of car, over gearlever
The gaitor is attached to the underside of the console with a small metal plate secured with 4 small screws.
Refitting is a simple reversal of the above steps :laughing
Good luck :D
216secoupeessex
Thanks seems easy enough - how do you get the radio out is there a special tool?
216secoupeessex wrote: Fri Aug 07, 2020 2:04 pm Thanks seems easy enough - how do you get the radio out is there a special tool?
If it's a standard Philips radio there's a U-shaped tool that goes into the pair of holes at each end of the headunit. Having 2 of these tools makes it very easy but you can manage with one.
Alternatively, 2 long, stout pop rivets can be used but they're a bit more of a faff...
Post by 961tat »
Or you can use allen keys :D
