Search found 12 matches
by rwd fan 2
Fri Apr 27, 2012 10:26 pm
Topic: Mystery Coolant Leak
Re: Mystery Coolant Leak
possible heater matrix leak??
by rwd fan 2
Tue Apr 24, 2012 11:12 pm
Topic: 216 GTI DOHC TC - stock VS upgraded questions
Re: 216 GTI DOHC TC - stock VS upgraded questions
sohc flywheel and clutch are same as dohc.
by rwd fan 2
Thu Sep 15, 2011 10:28 pm
Topic: B18 into R8?
Re: B18 into R8?
Very helpful thanks :)
by rwd fan 2
Wed Sep 14, 2011 8:33 pm
Topic: B18 into R8?
Re: B18 into R8?
thanks,i wonder if the R8 was honda engined before swap originally?
by rwd fan 2
Wed Sep 14, 2011 6:14 pm
Topic: B18 into R8?
B18 into R8?
I'm hoping to put the B18 Honda(1800 dohc v tec) engine into my honda engined 216, can anyone shed any light on whether engine mounts line up,gear selecter matches up and drive shafts fit hubs? thanks...
by rwd fan 2
Sat Aug 06, 2011 11:22 pm
Topic: Honda D16 SOHC engine interchangability
Re: Honda D16 SOHC engine interchangability
I don't think threre's any difference between man/auto engines,if your going to change engines it's definately worth putting in twin cam honda engine,a very easy swap...
by rwd fan 2
Wed Jan 26, 2011 10:16 pm
Topic: Honda DOHC V SOHC Gearbox
Re: Honda DOHC V SOHC Gearbox
Brilliant, thanks for that!! :)
by rwd fan 2
Tue Jan 25, 2011 11:58 pm
I'm trying to find the ratio's for each gear on these two gearboxes also do they use a different diff ratio? is there a way of telling externally which gearbox is from which engine i.e dohc or sohc? any info appreciated.
by rwd fan 2
Sun Dec 06, 2009 7:54 pm
Topic: snapping driveshafts
Re: snapping driveshafts
I snapped a drivers side shaft last nite but this was in a banger race! i had a hard impact on passenger side but the drivers side broke,generally the shafts seem quite strong but i always carry a spare.I don't think rust would cause it,more so the forces twisting the shaft.
by rwd fan 2
Wed Oct 28, 2009 6:00 pm
Topic: Rev limiter 216 honda engine
Re: Rev limiter 216 honda engine
Many thanks for your replys ta.
