Search found 98 matches
by mort2156
Tue Mar 12, 2013 9:44 pm
Topic: a little help needed
i have started noticing that my key fob for my coupe works less and less so i replaced the battery and it now dont work on the fob so my car is stuck as i can not disable the immobliser
is there any way of disableing it or does anyone know of somewhere i can send the fob for fixing :S :S
jon
by mort2156
Mon Nov 19, 2012 7:58 pm
Topic: fuel rail
Re: fuel rail
yep the rail will fit as long as you get one designed for the d16
by mort2156
Mon Nov 19, 2012 7:56 pm
Topic: River 216 D16
Re: River 216 D16
easy way to get more power would be a new fuel rail and new injectors to increase fule flow add an air filter if doing the fuel rail then add a 4-2-1 exhaust manifold and de-cat the exhaust the exhaust on my d16 engine is a honda civic sports exhaust. from the top of my head it cost me about £110 fr...
by mort2156
Sun Oct 14, 2012 6:05 pm
Topic: coupe rear window
coupe rear window
hi my coupe rear window rubber surround plastic thingy has started to pop out does anyone know of any reason for this or will i be needing a new surround for the window?
many thanks jon
by mort2156
Sun Oct 14, 2012 5:55 pm
Forum: The Gallery
Topic: addition to my rover family
while doing the full restoration of my cabby and sinking another £800 for welding into it i didnt realise how much work goes into a full restoration its been 18months so far. not to mension the cost so far im upto £3400 or there abouts not including the cost of buying the car. so to keep me going wi...
by mort2156
Sun Apr 15, 2012 10:31 am
Topic: Metallic paint polishing and cutting.
Re: Metallic paint polishing and cutting.
if you are going to use G3 i would first make the panel you are buffing very wet to avoid buring the paint or wet your mop first
jon
by mort2156
Tue Apr 03, 2012 9:26 pm
Forum: The Lounge
Topic: not sure if it goes here
im lookinig for parts as i do surfing the net and i came accross this website http://www.rovercarpartsuk.co.uk/
does anyone know of this company or used them before?
jon
by mort2156
Thu Feb 09, 2012 9:30 pm
Topic: biggest bill
biggest bill
i was due to have the car resprayed before christmass so i took it out of my workshop for a thrash round the yard as i hadent driven it for 9 months or so while i have been stripping and replaceing parts when at about 20mph and 3000 rpm the cam belt went :o :o :o OMG that is the first time i have ev...
by mort2156
Mon Nov 28, 2011 10:20 pm
Topic: 124 miles per tank wtf
Re: 124 miles per tank wtf
check the fuel sender unit first might just be giveing you a false reading
by mort2156
Mon Nov 14, 2011 9:33 pm
Topic: fuel rail
fuel rail
im looking at getting a new annodised fuel rail for my cabby ( d16a8 ) does anyone know if another d16 fuel rail will fit ??
