Search found 6 matches
- Wed Jun 22, 2011 10:38 am
- Topic: SRS Warning light
Re: SRS Warning light
Many thanks to both of you for your prompt replies, I tried starting the car this morning but the battery is now flat, checked all leads and they seem to be ok. is it worth getting the battery recharged!!!?
- Tue Jun 21, 2011 1:08 pm
Many thanks for your reply, is it possible for you to direct me to the Earth Strap or Slam Panel, sorry for being so ignorent!!!!
Rita
Rita
- Tue Jun 21, 2011 11:24 am
Hi I have sorted the problem with SRS warning light, thanks to you, but a new problem has reared its ugly head and that is when I tried to start the car it just kept making a burring sound, I had to get the aa to tow me home, the next day I tried starting the car again and it atarted first time so d...
- Mon May 23, 2011 12:23 pm
Thank you for your advice, I tried it and it was a connection problem behind the front seats, everything seems to be working ok now, many thanks once again....Rita
- Sun May 08, 2011 11:56 am
Many thanks for reply, will go and have a fiddle and hopefully correct problem, will let you know the result.
- Sun May 08, 2011 10:08 am
SRS Warning light
Hi I have just joined the forum, so am not too sure of what to do, so I will just ask my question and hope that someone will be able to help. I have got a Rover 45 and I keep getting the SRS warning light staying on intermitantly. I have been told by the garage that it is a common fault with Rover c...
