Search found 21 matches
- Tue Sep 25, 2012 3:09 pm
- Topic: Rear Subframe Replacement
Re: Rear Subframe Replacement
Many thanx guys! I managed to get the steering rack out (needed to take of a track rod end on one side). I thought rest is going to be easy...but how the **** do you take off the rear engine/tranny mount on a 216 GTI? The one that comes attached to the subframe? Im seriously without ideas as some bo...
- Mon Sep 24, 2012 7:37 pm
crepello many thanx for this - unfortunatelly, I started disasembling it before I got the chance to read this... Why unfortunatelly? Well, I disconected the steering column from the rack in the footwell, but then found out, I took out the upper part of the joint-ball aseembly instead of the bottom o...
- Sun Sep 23, 2012 4:55 pm
- Topic: 216 TC AC removal and radiator replacement
Re: 216 TC AC removal and radiator replacement
Many thanx for that! The reason I would like to know how the wiring goes is the fact AC uses quite a lot of wires + a separate relay/fuse box. Removing those would clean up the bay quite a bit!
- Sun Sep 23, 2012 3:09 pm
Thnx for reply - but Im a bit unsure about what you meant with saying that my rad is dead/dying?
I know that :P
- Sat Sep 22, 2012 7:11 pm
Hello, I decided to start working on my 216 GTI thats been parked down by the road for some time now. Plan was to take care of all the rust and do a major service. I also decided to completely remove the AC because I rarely need it and I meant to have this Rover as a fun car...now, the questions reg...
- Sat Sep 22, 2012 6:51 pm
Guys, sorry to dig out this old thread but Im in a bit of a hurry :( I decided to leave my partially rotten subframe in place on my 216 TC but when taking the stabiliser off, one of the bolts broke the welded nut. So now it has to come off... Given the fact, Im working alone, are there any tricks th...
- Sun Apr 29, 2012 8:48 pm
- Topic: 216 GTI DOHC TC - stock VS upgraded questions
Re: 216 GTI DOHC TC - stock VS upgraded questions
Thnx for replies guys! Tegiwa unfortunatelly, wasnt much of a good use (terrible email communication) so Im left with further searching - so far, the idea of having a stock clutch and a lighter flywheel sounds as a very good (and fairly cheap) one - any other ideas where I could get uprated clutch (...
- Fri Apr 20, 2012 5:59 am
- Forum: The Gallery
- Topic: Pride Of Longbridge 2012 - Loads of Pix
Re: Pride Of Longbridge 2012 - Loads of Pix
Amazing pics and amazingly clean MGs & Rovers!
- Thu Apr 12, 2012 9:14 am
Geo - didnt thank you yet for the link - thnx! This a straight bolt on fit I presume? The only problem I see now is high postage - they want 300 USD for shipping to Slovenia. Plus, theres VAT and custom fee. I was looking at this: http://www.tegiwaimports.com/f1-racing-stage-1-clutch-kit-honda-d-ser...
- Sat Apr 07, 2012 7:59 am
Due to low mileage I started to suspect the cable myself. Will check it. Took it for a drive yesterday and im very pleasantly surprised. I did notice though, that I have the cat version with 122 hp :/ Can anyone tell if I can decat it with no fueling or ECU problems? I have read a lot about it but c...
