Search found 229 matches
by Cromp85
Thu Feb 26, 2026 4:46 pm
Topic: Cabriolet boot inaccessible
Re: Cabriolet boot inaccessible
You are halfway there with the seat base out!
If you unbolt the middle bracket that holds the rear seat backs, you can move one side enough to get you arm in and pull a seat realease. With both seat backs out the way you should be able to squeeze through the gap and open the boot.
by Cromp85
Sat May 03, 2025 12:55 pm
Topic: Rover 214 Stepper Motor
Re: Rover 214 Stepper Motor
How many club members need one of these stepper motors? Is it worth me sorting out a few units to bring along to a show this summer?
by Cromp85
Fri May 02, 2025 2:30 pm
Slate13 wrote: Tue Apr 29, 2025 2:22 pm Cool. How much for the stepper motor. Mine is the 16v 1.4 k series mpi
In reply to an earlier post with a photo of a stepper motor, yes that looks very familiar
Thanks.
£40 for a known working one, I have 3 of these. I also have a few more either on a TB, in its alloy housing and one bare.
by Cromp85
Tue Apr 29, 2025 9:23 am
Hello all, Following diagnosis from two separate mechanics I need a new stepper motor (air intake control valve) for my 1992 Rover 214, but as the car is the early SPI 16v K series engine it is proving very difficult to find one… I have tried rimmer bros, Xpart, ebay, all the usual places but they ...
by Cromp85
Mon Apr 21, 2025 9:38 am
Forum: Events and Meetings
Topic: Pride of Longbridge 2025
Re: Pride of Longbridge 2025
1. Montegoman
2. Hammond
3. Hobby (Concerto!)
4. MGZRreplica
5. Noahlandycumbria
6. Yorkshireman (Rover 45)
7. Kingspoons
8. G259FSG 1990 Rover 214 GSi
9. Cromp85 (216 Coupe)
by Cromp85
Mon Jul 29, 2024 9:53 am
Topic: Boot lid required!
Re: Boot lid required!
I have just broke a low mileage 416 saloon with front end damage so I have everything from the rear end.
by Cromp85
Sun Jul 28, 2024 8:43 pm
Paul_1978_yorks wrote: Sun Jul 28, 2024 7:21 pm Isn't your car a saloon? Don't end up with a "tailgate"!
We have at least 1 saloon boot :laughing2
by Cromp85
Sun Jul 28, 2024 2:52 pm
I work at a small mg rover specialist, I can supply and fit a good used tailgate for your 400. If we dont have one the same colour, we can also paint. My works is located in Cradley heath, about 10 miles from you.
I can send a PM with my number and the unit address if you want.
by Cromp85
Fri May 10, 2024 11:30 pm
Topic: 420GSI Turbo MKC101960 ECU
Re: 420GSI Turbo MKC101960 ECU
Have you checked the slam panel earths? I think there is a black thin gauge wire going to the ECU, a break or corrosion on this and the engine won't run.
by Cromp85
Thu Mar 28, 2024 10:38 pm
Topic: Crankshaft Pulley Removal
Re: Crankshaft Pulley Removal
I have only done two d16 cambelt changes and both were a pain. The first was on my own car, lockup tool broke a chunk off the pulley as the nut was so tight, ended up removing the starter motor and locking on the flywheel. The second was HHR Civic, locked at the flywheel and needed a scaffold pole t...
