Search found 1193 matches
by ROVER Cabby
Tue Jan 21, 2025 12:22 am
Topic: R8 binnacle illumination
Re: R8 binnacle illumination
No problem. You could sell the ones you use on to someone else.
If they are LED, I might be interested.
by ROVER Cabby
Sat Jan 18, 2025 4:15 am
Topic: Cabriolet and Coupe Boot Deleted as no longer required the same?
Re: Cabriolet and Coupe Boot Lids the same?
I have seen a bootlid with the spoiler off a coupe and quite fancy it as its the correct colour.
I'll have to remove the areal and fit a rubber bung though as it will interfere.
by ROVER Cabby
Fri Jan 17, 2025 9:22 pm
Topic: Rover 416GSi 1990 misfiring after storage
Re: Rover 416GSi 1990 misfiring after storage
As mentioned above, check the plugs, leads, cap.
I'd also check for a vacuum leak by spraying brake cleaner around vac hoses and the intske manifold.
by ROVER Cabby
Fri Jan 17, 2025 9:18 pm
Topic: Archive of the old Rimmer Bros Parts Listings?
Re: Archive of the old Rimmer Bros Parts Listings?
Agreed, it would be a valuable source.
I'm not a fan of pay walling, but if this info was added to the site, it should be a paid members perk.
by ROVER Cabby
Tue Jan 14, 2025 12:53 am
Johnny 216GSi wrote: Mon Jan 13, 2025 2:19 am I've just read this thread. I didn't have to look too far:
https://www.ebay.co.uk/itm/23540881527
Otherwise, buy branded T5 and T6.5 bulbs, such as those made by Osram.
Linky no worky pal, think it's short a number.
by ROVER Cabby
Tue Jan 14, 2025 12:49 am
Where can I find these please? I’ve been struggling! Also does anyone know of an effective orange filter (paint or sleeve) you can buy to put over it? I had a look on eBay and found these in orange. I will warn you, although the seller lists them as being LED, the illustrations are of conventional ...
by ROVER Cabby
Tue Jan 14, 2025 12:44 am
As per title.
I'm trying to cross reference some R8 parts, but Rimmers only have partial listings these days, as they don't list times that they don't sell or are unavailable.
They used to have a list of part numbers on a numbered list breakdown. Does anybody have these archived somewhere?
by ROVER Cabby
Sat Jan 11, 2025 10:27 pm
I would go LED.
You can get T6.5 in LED guise prefitted with resistors.
If you want to keep the factory look, go with warm white.
