Search found 24 matches
- Sun Mar 09, 2025 7:14 pm
- Topic: The Age Old Immobiliser Topic - 2003 Rover 45 2.0 L Series
Re: The Age Old Immobiliser Topic - 2003 Rover 45 2.0 L Series
Just a thought - Englishman Herbert Arkroyd Stuart had a compression oil engine (no sparks) engine running 6 years before Diesel..................
- Sun Feb 09, 2025 3:17 pm
- Topic: Honda engine oil in plug holes
Re: Honda engine oil in plug holes
Hello. last possibility could be the pcv valve. Any one know where it is and a part number?
- Wed Jan 15, 2025 4:02 pm
Hello. Please can anyone help? I've oil collecting in spark plug holes - about half an inch every 500 miles. Not all fill up equally. I renewed the rocker pillar o rings at their bases and also the seals in the rocker cover to no effect. Could it be the PCV value and if so where is it and does anyon...
- Mon Jul 03, 2023 6:22 pm
- Topic: Honda Engine 216 Oil In Plug wells
Re: Honda Engine 216 Oil In Plug wells
Hello. I've checked out the links but the engine top cover gasket sets appear to have the four seals that fit the top of the plug holes - ie underneath the cover. They do not seem to be "o" rings or have I got this wrong. I'm after the o rings that fit underneath the rocker shaft mounting ...
- Tue Jun 27, 2023 8:07 pm
Thank you Colonel - I didn't find when searched but I am 70 and grapple with computers!
- Tue Jun 27, 2023 9:56 am
Hello - My wife's 216 (15300 miles on the clock)! developed a misfire which turned out to be oil in the no 2 plug well which had pushed the plug lead out. The others had oil in as well but not so much. Surprised it ran with everything under oil. I've met this on my K series Rover 75 which has a spec...
- Thu May 11, 2023 9:36 am
- Topic: 1993 216 plenum drains
Re: 1993 216 plenum drains
Thanks for the advice.
- Wed May 10, 2023 9:19 am
Hello Again,
Seems to be the windscreen after all. Daft question - can I re bond / seal or does the glass have to come out?
- Tue May 09, 2023 5:29 pm
Thank you for your replies. I'll check the drain holes first just in case and then move on to the bonding.
- Mon May 08, 2023 8:06 pm
Hello - can anyone advise where the plenum (bulkhead - where the wiper motor lives) drains are and how the grills come off? I've got water leaking into the footwell during heavy rain which appears out of the heater. Thanks
