Search found 18 matches
by phil.coyle
Mon May 18, 2009 10:42 am
Topic: radio code
Re: radio code
Try www radio-code.co.uk, if you can get the radio out you can match the serial number on their list, and then follow the instructions
Phil.
by phil.coyle
Tue Apr 21, 2009 2:50 pm
Topic: Please Help me
Re: Please Help me
It sounds like you need your front disc pads looked at. There is a metal strip on the brake pads that vibrates when it touches the disc, and it sounds like the wail of a banshee.
Phil .
by phil.coyle
Tue Oct 14, 2008 6:57 pm
Forum: The Lounge
Topic: scam
scam
Postal Scam Can you circulate this around especially as Christmas is fast approaching - it has been confirmed by Royal Mail. The Trading Standards Office are making people aware of the following scam: A card is posted through your door from a company called PDS (Parcel Delivery Service) suggesting t...
by phil.coyle
Sat Aug 30, 2008 6:06 pm
Topic: Battery not charging but alternator ok?
I have had this happen to me on a vehicle before, can't remember which one (old Timers disease), but it turned out to be the starter remained engaged when I fired up the car. Subsequentialy the starter ran on until I switched off, and if that was after a long journey the battery would be flat.Not ha...
by phil.coyle
Thu Jul 24, 2008 4:16 pm
Topic: Parts needed
Thanks for the quick reply, will go looking for a shim type head gasket.
Now then where did my missus leave her purse?
by phil.coyle
Thu Jul 24, 2008 9:37 am
Topic: Parts needed
Parts needed
Can anyone give me any info on :scared where to source a head gasket for my K8 engined 214i (96). So far I have been offered a shim type, and a composite type gasket, both claiming to be the MODIFIED one, and no manufactures name on the packet. I know Land Rover did some mods on the Disco head gaske...
by phil.coyle
Thu Apr 24, 2008 8:48 am
Topic: rover 220gsi immobiliser fault ?
Sam
I got the info from a friend who programs ecu's immobilisers and such like, he still insists that if you press only the locking button on the fob eight times this will program the new fob or the old one.
Phil
by phil.coyle
Thu Apr 10, 2008 7:30 am
Topic: Erratic engine idle and override
David,
I recently fitted a new thermostat in my 214i, and found out, thanks to the parts chap that there are 2 types of stat. One has a plastic housing, the other a cast one , the stats are different might be worth while checking yours.
by phil.coyle
Tue Apr 01, 2008 3:11 pm
Sam
sorry, but the info should be ,press remote locking button on the fob 8 times, and not the drivers door as I said before, and then the horn should sound.
Phil
by phil.coyle
Sun Mar 30, 2008 9:27 am
Hi Sam
You could try this piece of info I have picked up.
First make sure the remote has a new or working battery in it.
Sit in the car with all doors closed and press the drivers door button 8 times, not too fast, if all is working okay the horn should sound.
Phil
