Search found 20 matches
- Sun Dec 06, 2020 7:17 pm
- Topic: Which things will kill our cars? Common faults?
Definitely have a look around the rear lamp seals: if you are lucky, tightening up the three small nuts that hold the lamps in place may be all you will need to do. There are a couple of other things to check while you have the trims removed inside the boot: The sunroof drain tubes run down to a ru...
- Sun Dec 06, 2020 10:40 am
I'll be getting on that. Id originally thought it was from the inner wheel arch. but having the car sat for 2 days in low and heavy rain (not my choice) i found that thankfully it wasnt the casemontegoman wrote: ↑Thu Dec 03, 2020 8:58 pm The R3 suffers from leaks around the rear lights. Check the seals around the light fittings.
- Sun Dec 06, 2020 10:38 am
I was toying with this. didnt fancy dismantling the rear of the car. but looks like I'll have to. Currently have a mobile aquarium in the wheel well
- Sun Dec 06, 2020 10:36 am
It's never the sunroof guttering or drains. Unless the metal undertray has rotted through, but you'd be getting a soaking wet headlining and I don't expect you are. Glass de-bonding is the main cause on the R8 - any water at the front is 99.999% certain to be the windscreen debonding. I'd suggest t...
- Thu Dec 03, 2020 12:19 pm
Hi all. I'm having trouble with water ingress in a few places in my 2004 streetwise s. one area is the sunroof (think i need to clear the guttering from it) Last night i took the boot carpet and floor out to find my spare wheel well has about 2 inches of water sat there like a naughty little pond. S...
- Mon Nov 30, 2020 8:03 pm
- Forum: Announcements and Information
- Topic: Stolen!!!
Re: Stolen!!!
Been scouring the internets for about 4 hours now. trying any website I can find (even some my virus software said "don't go there mate....unless you have a weapon"). tried whole cars and parts. Cannot find anything not even any pictures relating to the car or parts (this particular one). ...
- Mon Nov 30, 2020 1:58 pm
- Topic: Stolen!!!
Re: Stolen!!!
Hi Everyone My Good mate and friend of the club Craig Cheetham has had his 1989 Rover 214 Stolen Last seen in Chatteris on 22 Nov 2020 Flame Red Rover 214 REG G899UYP If you spot it please ring 999 and PM Me please Thank You for your help Matt you got a picture? might help us if we see one for sale...
- Sun Oct 18, 2020 1:12 pm
- Topic: Sound upgrade for Streetwise plus a little body work
Re: Sound upgrade for Streetwise plus a little body work
Real wood surrounds... that's true hi-fi :laughing2 Now if you could only fashion the entire front NS and OS doors out of chipboard, add some acoustic wadding and replace the door cards with a hardboard frame covered in acoustically transparent cloth, you'd be a real audiophile... :laughing2 I expe...
- Mon Oct 12, 2020 11:05 pm
- Forum: Introductions
- Topic: New to rover
Re: New to rover
https://imgur.com/px8iqUsRoverRevival wrote: ↑Tue Jun 23, 2020 2:14 pm Rimmerbros has them on the shelf but it’s a pig of a job to swap.
https://imgur.com/21M4DyY
All done. fortunately the old knackered badge was hanging on by a thread. May the job less Pig like and more piglet
- Mon Oct 12, 2020 10:59 pm
I dunno.....if you put enough paint on anything you can get a good enough finish, might end up being an inch or so thick tho (real widebody) :D Decided I'm going to build a couple of half trapeze shaped boxes for the rear speakers and Velcro them to the parcel shelf. Means i dont have to file/sand/c...
