Search found 7 matches
by PGTips
Thu May 11, 2023 3:13 pm
Topic: Rover 416 - Spark plug tube seals
Re: Rover 416 - Spark plug tube seals
I’ve always found Parts in Motion very reasonable but that’s only my personal experience. Although when I asked them to do a check on all the parts I needed to do a Cam-Belt change they told me that the water pump I had selected wasn’t compatible despite their website saying it was compatible when ...
by PGTips
Wed May 03, 2023 7:42 pm
I got mine at Parts in Motion for my R8 416. It was part of a Rocker Cover Gasket set. The whole gasket set is about £8 and was for a Twin Cam https://www.partsinmotion.co.uk/car-parts/engine-parts/gasket-seals/rocker-cover-gasket/bga-gasket-set-cylinder-head-cover-rk6301-detail After I fitted them...
by PGTips
Wed May 03, 2023 4:52 pm
Rimmer Bros got back to me with what they think is the part. It's Item 5 on the list if anyone is ever looking for them...
Washer-rubber - FDU1302 - Genuine MG Rover
https://rimmerbros.com/Item--i-GRID003266
by PGTips
Wed May 03, 2023 2:33 pm
I have oil in all 4 spark plugs on my 1996 Rover 416 Sli Auto. I think the spark plug tube seals need replaced. I've tried Rimmer Bros but it's not looking good. Does anyone know where I can get a set from?
Thanks
by PGTips
Wed Aug 24, 2022 1:27 pm
Topic: Rover 416 ODB Socket / ABS Fault
Re: Rover 416 ODB Socket
It looks like it's an HH/R. Do you know about how to go about diagnosing ABS fault codes given there are only 2 wires going to the ODB Socket?
by PGTips
Wed Aug 24, 2022 12:14 pm
RoverRevival wrote: Wed Aug 24, 2022 11:23 am you don't say if R8 or hhr but the abs plug is under the drivers seat on r8
I've had a look under the drivers seat, and there is nothing under there. I take it that means it's an HHR?
by PGTips
Wed Aug 24, 2022 10:34 am
Hi, I have a 1996 Rover 416 SLi Auto. It recently started showing an ABS warning light first thing in the morning. The ABS warning usually disappears for the rest of the day after the first run. A mechanic was going to check for fault codes, but he discovered that there are only 2 wires connected to...
