Search found 44 matches
- Fri Jun 13, 2025 10:03 am
- Topic: Immobilised
Re: Immobilised
Tried the key in the drivers door thing again today and still immobilised. Looks like a new programmed key fob it is! I have one but it has never worked, I always used the other one which did (now lost). Please can someone tell me where the 5AS ECU is located? Or do instructions come with the order...
- Tue Jan 21, 2025 4:58 pm
Re: Immobilised
Tried the key in the drivers door thing again today and still immobilised. Looks like a new programmed key fob it is! I have one but it has never worked, I always used the other one which did (now lost). Please can someone tell me where the 5AS ECU is located? Or do instructions come with the orderi...
- Tue Jan 21, 2025 10:34 am
Re: Immobilised
OK - early 5AS for sure. We can fix it in the RCOC for you. If you can post us your 5as ecu and fob Order here:- https://store.rover-coupe.com/services/56-162-lucas-5as-ecu-fob-postal-matching-service.html#/27-5as_matching_options-5as_matching_no_supplied_fobs if you have other fobs, we can prorgra...
- Mon Jan 20, 2025 1:37 pm
Re: Immobilised
- Sun Jan 19, 2025 2:01 am
Re: Immobilised
As is says in my signature, 1994 Rover 216 SLi it is also Auto 1.6 petrol with the honda engine, R8 platform.
Got a Lucas key fob that doesnt work.
Tried doing the key code in the drivers lock but its still immobilised.
- Sat Jan 18, 2025 2:34 pm
Immobilised
After the car being stood for a year the battery was flat. Jumped using another car and alarm went off straight away. Now car is immobilised and will not turn over. Replaced fob battery. Still nothing. Have tried pressing the button on the fob numerous times, nothing. Have tried the key in the drive...
- Mon Mar 27, 2023 8:07 pm
- Topic: Cabriolet Front Strut Brace
Re: Cabriolet Front Strut Brace
That looks awesome
Love the colour of your car too.
- Thu Feb 25, 2021 10:50 am
- Topic: Boot problems
Re: Boot problems
Thank you 99% of the time its the plastic buffer that wears away perhaps we could 3D print this part one day 🤔 That would be helpful as it seems to be a common problem. Inevitable really when you mix plastic with metal parts, would it not be better to make one out of metal? Or wouls that just poten...
- Mon Feb 22, 2021 9:41 am
- Topic: Rear Light Cluster Leak
Re: Rear Light Cluster Leak
I have this mysterious wet boot issue too... I was in the boot all afternoon yesterday after detailing the car. All areas mentioned above are bone dry... apart from the area around the base of the vent on the passenger side. I assume this is just down to condensation and there is not a lot I can do ...
- Mon Feb 22, 2021 9:22 am
- Forum: The Lounge
- Topic: Electrification of Classics-yes or No?
Re: Electrification of Classics-yes or No?
I'm sorry I just don't think you can retain the original 'feel' of an older car with an electric motor, you just can't. It's a facsimile. It's like a Western town film set, with nothing real or relatable to the façade behind. It's clever, yes, but ultimately, soulless, eg there's no way you could c...
