Search found 21 matches
by Oldroverdiesel
Fri Apr 22, 2022 3:16 pm
Topic: Repair manual
Re: Repair manual
Hi,
Fairly sure they did one, try searching on eBay for Citroen Diesel engine haynes manual, or Rover diesel Haynes manual. There are plenty on there.
I had one but gone to the tip unfortunately or you could of had it!
Cheers
by Oldroverdiesel
Wed Apr 13, 2022 6:36 am
Topic: 200/25 Rear drum brakes
Re: 200/25 Rear drum brakes
Hi
Just try your local motor factors, get a couple to have a spare.
Regards
by Oldroverdiesel
Wed Apr 13, 2022 6:33 am
Topic: MOT advice for a new member/owner
Re: MOT advice for a new member/owner
Hi Have you had a go at the suspension bush yet? Don’t think it is the same as the 45 if it has a beam axle. The 45 has independent arms on the rear with a large bush that bolts to the chassis on the arms that support the wheels. These bushes are a common mot failure so I changed both mine during lo...
by Oldroverdiesel
Fri Mar 18, 2022 8:02 am
Hi, Fan fault common one easy to fix have a look at DMGRS.co.uk they do a repair kit for £3.99 They might do the bushes for your suspension but also have a look at Rimmer Brothers, they might be able to get you the brake pipes but I’d make the copper ones easier and cheaper. Your Streetwise rear sus...
by Oldroverdiesel
Sun Mar 13, 2022 3:00 pm
Topic: Power Steering Leak
Re: Power Steering Leak
Hi,
I just tightened the clips a bit that sorted it, can the reservoir be slid out of its bracket to make access easier?
by Oldroverdiesel
Sun Mar 13, 2022 2:57 pm
Topic: Veg oil?
45 values?
Thanks for your comments, have a few litres in stock so might use them up in the tank later, but only intend to do a few miles this year in the old Rover so won’t save much really.
On a separate topic what are good 45 diesels worth these days?
Cheers
by Oldroverdiesel
Thu Mar 10, 2022 8:06 am
Topic: Veg oil?
Re: Veg oil?
Hi,
I ran my older 400 on a light blend but that had the earlier injection pump on so just wondered if the later 45s can cope with it too.
Might give it a little drink when back on the road.
Regards
by Oldroverdiesel
Tue Mar 08, 2022 5:41 pm
Topic: Veg oil?
Veg oil?
Hi,
With the current sky rocketing diesel prices is anyone running their L series diesels on a blend of veg oil and diesel?
Would be particularly interested in any member running the later 45 diesel with the vp30 Bosch injection pump.
Regards
by Oldroverdiesel
Wed Jan 19, 2022 2:47 pm
Topic: Insurance
Re: Insurance
Thanks for the link will give them a try roo.
by Oldroverdiesel
Sat Jan 15, 2022 6:51 am
Topic: Insurance
Re: Insurance
Hi,
Thanks for your replies will give Lancaster a go later this year and see what they quote.
Mine is my second car had to get a modern one for daily use after many years of Rover service as my daily commute and cheap running costs!
Regards
